| Home | Forum | Resources | T-Shirts & Etc | Music | Photos | Reviews | Classifieds | Register | FAQ | Search | Today's Posts | Mark Forums Read |
Rat build/mods
I'm starting my Rat clone distortion pedal build...
Any thoughts? Tips? Most importantly, any mods you'd recommend? This sucker has a lot of caps in it...
- 3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, and a Smith & Wesson SW40VE = too many toys, no money, carpal tunnel, and a serious hearing problem. |
Attaching the clipping diodes to a switch is a pretty popular mod.
The classic Rat uses 1N914/1N4148 diodes, the Turbo Rat uses 3mm Red LEDs. Gets you a nice variety between lower gain, fuzzier distortion with the silicon diodes and a higher gain, more overdriven sound with the LEDs.
![]() "I just sang a song parody, Dad. Like Weird Al Yankovic." "Son, Al Yankovic blew his brains out in the late 80s after people stopped buying his records." |
1.- no 2.2uF caps in FBloop og LM308
2.- LM308 for sure 3.- tants caps for coupling caps (like vintage original rat) 4.- 2N7000 mosfet clipers (or even with a ASYMETRIC 1N60 germanium diode) 5.- 50K pot for GAIN and 100K pot for FILTER 6.- 4,7K resistor as minimun gain resistor (before the GAIN pot) that's it... and ENJOY!!!
Watch my Blog with DIY Tube Amps and Boutique Effects from CHILE : www.richon-caster.blogspot.com |
#4 (permalink) | ||
How does omitting the 2.2uF caps change the sound? Darker, less gain? Quote:
I've got a LM308N. The caps are box types (poly film), except for the bigger ones. I have 1N914 clippers as per the GGG schematic... I might put the clippers on sockets so I can swap back and forth. Thanks for the tips on the mosfets. Quote:
I'm broke, so I have to settle for 100k pots all around. The GGG schem calls for 100k pots and a 1k gain resistor. What differences in tone should I expect?
#6 (permalink) | |
Not to hijack the thread, but on the subject of RATs, would the LM741CN op amp I picked up from Radio Shack be an improvement over the stock Texas Instruments op-amp? The name is at least similar to the LM308N...
"Someone in the newspaper said that it was art." -Nick Lowe |
#7 (permalink) | |
I've had too many Scotches and beers and it's 1:30am, but so far looking at both datasheets, they look a little different. I'm soldering a chip socket onto my board so I can swap different chips to taste-test... maybe this would be an option for you too? If I can scrape together the dimes, I'll try the chip you mentioned...
#8 (permalink) | |
This sounds similar to what richon was suggesting.... I've already got a TS808 overdrive and a Clean Boost, then I've got a Red Llama overdrive in the works. I think I may keep the Rat a little closer to stock and cover my distortion bases a little more. I've got my OD's and boosts covered... I've got my fuzzes and germanium OD's covered too (Big Muff and a Rangemaster), but only a Guvnor and DS-1 for dist.
#9 (permalink) | |
LM308N is the way to go Poly's are fine (but do try TANTS, please... the add character to the sound, and even a little more clear guitar sound through) 100K are fine... I used 50K for GAIN pot to have a even more controlable OVERDRIVE (before DISTORTION) sound. the 4.7K gain resistor , that i was talking about, is adding it to one leg of the GAIN pot to set the minimun GAIN the pot controls. you know, the RAT at CERO gain, doesn't sound really good.
I don't like tantalums in dirt boxes, but must admit that they sound really good in a Rat.
I will also repeat that the LM308N is a special chip for two reasons - it has horrible slewing capabilities, and it's externally compensated. Looks bad on paper and for hi fi applications, but is magic in this pedal. When you clip part of the dual tail on a stock Rat, you're also killing part of it's essential character. The high pass filter that's around 1.5KHz is necessary to get those classic tones, IMO. When you hear them on the Jeff Beck stuff for example, I just couldn't imagine it w/o them. I like to reduce the compensation cap, which really opens up a Rat, but doesn't lose the core character. You can go as low as roughly 3pF, but I find 10pF to work pretty well. Lotsa people miss this aspect altogether. The part that's removed with the Ruetz mod I swap with a 100 ohm/1uF pair, which makes it a little less overt. Clippers again are a taste thing. I've personally found that when the compensation cap is reduced (in conjunction with tweaking the ~1.5KHz high pass), that the stock silicon diodes work very well. I also personally prefer running a 20K pot with a .018uF cap for the Filter circuit, but you can get a multitude of sweeps with different pot and cap combinations. The Soul Sonic mods are some of the better ones that I've tried, and you can check them out here. Just bear in mind that Martin is very picky about caps, and has a stash of stuff that most tweakers do not! He's also got a sound clip of it here.
Newbie question: do you mean that, in place of the clipped resistor, you wire 2 100 ohm/1uF resistors in parallel? Or series?
#12 (permalink) | |
Scott Burnham,who constructed the original RAT,put a 47 ohm resistor in the prototype by mistake instead of a 470 ohm(he misread the colour of the multiplier).Since the chip couldnīt handle that amount of gain he got slewing distortion.That sound is unique for the RAT and separates it from all other distortion boxes which "11 Gauge" has pointed out.I find it ironic that the Ruetz mod take this resistor out of the circuit.
