How to - DIY "switch two pedals off and on at once" pedal
Hey guys! Just wondering if anyone knows how to do this? Or does anyone know of an already existing product thats simple in doing just this? Basically what i wanna do is have two overdrives on at once for my overdrive tone but am tired of quickly switching one on, then the other. I want to be able to be able to run them into a separate little box (preferably one button) that switches them both off and on at once as if they were combined to make one single stomp box. Any help is greatly appreciated! Thanks!
aaron |
Sounds to me like you are wanting an AB pedal. Easy to make. Check it out here: http://www.singlecoil.com/docs/ab.pdf
That should do it for ya! |
An AB box is for routing 1 signal to 2 outputs or 2 to 1 if you run it backwards. If you used this type of switcher, you would need to re-combine your AB channels to go to one input of your amp. Also, the one shown can only run 1 or the other. An ABY would do more, but still not get you where you want to go. You need an FX loop pedal. You can run both pedals out of one channel and by having both pedals turned on and ready to be switched in, you will be able to turn them simultaneously with one switch or bypass them with the same switch and have your un-effected sound pass to the amp.
This is a decent manufactored one: or even better for your needs, one fxloop cheap and in kit form: http://www.generalguitargadgets.com/...=216&Itemid=26 |
Boss LS-2
my afro ambient side project: http://www.myspace.com/theswyambusessions I play dancy bass here: http://www.myspace.com/casabellamusic |
#8 (permalink) | |
Aaron, if I understand your description correctly, you want to be able to add/subtract multiple effects to/from the signal chain by stepping on one footswitch, one time. If I got that correct, you need a loop switcher, not an A/B switch. The Radial and Morley products linked to above are (or appear to be) A/B switches. The generalguitargadgets kit does appear to be an loop switcher.
Other examples of commercial loop switchers are: Keeley Looper (http://www.robertkeeley.com/product.php?id=23) and Boss LS-2 Line Selector ( |
#11 (permalink) | |
Oops... you're right about the first one, I listed the wrong link. Should be this link: but the DIY link is a loop pedal...take a look at it again and you can also open their link to the layout and then it'll be more obvious. They have all the layouts and instructions for all their kits, very helpfull if you have components and spare cases at your house and want to save the $ of a kit. They are good kits by this company by the way. jc |
I have often run 2 boss distortion pedals and with the right layout can switch them both on and off at the same time.
If they're close enough you just press them with the same foot at the same time. Did it for years no problem. I run my 2 switch effects that way all the time as well. Is that too simple to be helpful ?
Livin' in the Past ,Present and Future is takin' up all my time..........
| "Fatter" "Rounder" "Thicker" still "Twangy" Tele pickups? | BMKindoll | Just Pickups | 48 | November 12th, 2009 08:35 AM |
| Reverb Tanks & Pedals: "boing" & "drip"? | ruger9 | The Stomp Box | 5 | February 22nd, 2009 02:59 AM |
| Multi FX pedals Vs. Many "single" pedals... | tannerw_2010 | The Stomp Box | 30 | January 1st, 2008 07:06 PM |
| Are "boutique" pedals overhyped? Barber LTD vs. Bad Monkey... | RomanS | The Stomp Box | 45 | October 22nd, 2007 04:33 PM |
| Age old question: "Fuzz", or "Overdrive pedals"? | Cyrithicus | Bad Dog Cafe | 14 | October 11th, 2006 11:06 AM |
