Old November 7th, 2009, 11:07 AM   #1 (permalink)
EHX Holy Grail repair, anyone help with a resistor value?
Hey all - I've got a Holy Grail pedal I need to fix for a friend - it still functions, but it had a mishap with a power supply and let out the magic smoke
Seems the first resistor on the circuit board got burnt out. It's what the power to the board comes into, so I assume it fused together, because the pedal still functions fine, but I noticed it and would like to replace it for reliability's sake.
Anyone got a Holy Grail they can open up, and check the value of R1 for me? It's the large SMD resistor on the top left of the board, marked R1, right next to where the red wire from the power jack attaches. It's on the top side with all the other components. This is on a Rev. A board, BTW.
Any help appreciated!
f13ndus is offline   Reply With Quote
Old November 8th, 2009, 01:54 PM   #2 (permalink)
Here's a picture of the board/burnt resistor, if it helps. R1, in the upper left of the board. As you can see, it's burnt too far for me to read the value off of it!
Old November 8th, 2009, 05:41 PM   #3 (permalink)
RomanS's Avatar
The bands are red-black-gold-gold, and it measures at 2.2 ohms in my HG.
Old November 8th, 2009, 06:37 PM   #4 (permalink)
Hmm, so by the bands it's a 2 ohm resistor. The burnt one measures at 4.8ohm, I figured if it was fused it'd be closer to zero...
Can't find a 2ohm in my "new" parts stock, time to go scour "parts" circuit boards! Thanks for the help!
What would the Holy Grail be Justinvs Amp Central Station 17 May 13th, 2009 07:48 PM
Holy Grail? Joel The Stomp Box 20 January 24th, 2009 02:50 PM
Holy grail or con job? motoxlifer Telecaster Discussion Forum 29 February 24th, 2008 05:04 AM
Holy Grail Plus? johnnykf The Stomp Box 1 November 25th, 2007 10:20 AM
Holy grail vs Holier grail kyle1167 The Stomp Box 0 July 10th, 2006 01:09 AM
