Old November 4th, 2009, 09:39 AM   #1 (permalink)
mrcrappypantson's Avatar
Ruetz Rat - Clip or desolder?
Does anyone know if the Ruetz mod can be accomplished desoldering? Or does must it be clipped?
Muff π
mrcrappypantson is offline   Reply With Quote
Old November 4th, 2009, 01:24 PM   #2 (permalink)
If you heat the lead, you can pull it up. If you don't like it, you should pull the board to reheat from the bottom to reverse the mod. Clipping the lead works, but you'd have to bridge the solder on the small leads that are left to reverse it. I think 'clipping the lead' was just a testament to how easy the mod can be, but I'd desolder it.
FenderLover is offline   Reply With Quote
Old November 4th, 2009, 01:48 PM   #3 (permalink)
Excellent, thank you so much!
Muff π
Old November 4th, 2009, 04:19 PM   #4 (permalink)
Which leg?
How do you know which leg to remove? I'm super new to this, sorry.
Muff π
Old November 5th, 2009, 08:12 AM   #5 (permalink)
11 Gauge's Avatar
Don't clip or pull it - put a trimpot in it's place. You can then "tune" the clipped frequency while playing through it, and get more of a customized tone that works personally for you (AND adjust the gain). I think that this is called the "Lube" mod, if you google around. Ruetz may have even added it on his webpage.
Old November 5th, 2009, 08:17 AM   #6 (permalink)
11 Gauge's Avatar
Either one will disable it - it doesn't matter.
I would not heat the lead from the topside - too much heat can damage the pcb traces (lift them or tear them). If desoldering, pull the board, use desoldering braid, and only put the iron on there as shortly as possible. If you reinstall the resistor, make sure that you don't have to use any force to get it back in. The holes should be completely clear and unobstructed.
Old November 5th, 2009, 09:20 AM   #7 (permalink)
Thanks everyone. It worked like a charm. 11G, I was thinking about the lube mod. One day soon...Thanks again.
Muff π
1st Vox clip JohnnyCrash Amp Central Station 10 July 11th, 2008 09:24 PM
My latest Tele + PODxt clip + Buffer2 clip InstituteOfNoise Twanger Central 6 December 2nd, 2006 05:16 PM
"Fuzztones for the Connoiseur"/Ruetz Mod clearfish The Stomp Box 1 July 20th, 2006 11:00 AM
New TIM clip >>>>> The Gainster The Stomp Box 7 January 28th, 2004 12:19 PM
What's the best way to desolder? Matt Plescher Tele-Tech 4 May 12th, 2003 04:59 PM
