Old October 28th, 2009, 02:19 PM   #1 (permalink)
JoeNeri's Avatar
Paint/Finish Removal
Is there a best way to remove an existing paint/finish on a pedal in order to get down to the raw metal and do a custom paint job? Thanks.
The blues is my business and business is good.
http://www.wellredcoyote.com/blues-dawg.html
JoeNeri is offline   Reply With Quote
Old October 28th, 2009, 08:46 PM   #2 (permalink)
11 Gauge's Avatar
If you're putting paint over top, just get it clean, maybe fine sand it a bit, shoot a little primer, and then put your new color on.
If you want to put some sort of translucent color over the bare metal, you'll need a stripper to remove (what I'm assuming is) the old powdercoating.
Stripper is nasty stuff, and removing powdercoating is particularly tough. While you could get it bare with regular stripper, I recommend "aviation" stripper, because it works, FAST.
Old October 28th, 2009, 09:20 PM   #3 (permalink)
JoeNeri's Avatar
Thanks.
Decal removal over finish.... brittwin Tele-Tech 4 January 9th, 2008 03:19 PM
Dodgy Grain Filling making paint removal a headache Trimac20 Telecaster Discussion Forum 7 January 7th, 2008 11:28 AM
poly finish removal Barbeque John Telecaster Discussion Forum 3 September 11th, 2007 08:38 PM
MIM paint finish MartinLesCaster Tele-Tech 3 January 31st, 2006 10:56 AM
paint finish Andromeda1968 Telecaster Discussion Forum 5 September 22nd, 2004 04:40 AM
