Old October 21st, 2009, 11:17 PM   #1 (permalink)
Here's One For Ya'
This is a follow up to the "Volume Pedal Blues" thread I started.
THIS INFORMATION MAY BE USEFUL OR IMPORTANT TO YOU.
After having problems with my Ernie Ball VP Jr, and discussing it on the previously mentioned thread, I e-mailed EB one last time.
This reply from them was very thorough, and contained the answer I sought. The person at EB who responded mentioned that one possible explanation might be that I had changed the order my pedals were in. I thought it was kinda' goofy, but electricity being the often inexplicable bugger that it is, I tried it.
Sure enough it freaking worked. I had altered my pedal chain by one, count 'em, one pedal. I returned the pedal order to its previous state, and voila! Taper problem solved.
I don't understand it, but it worked, so 'nuff said.
I wanted to post this as it might be helpful to someone, somewhere, sometime.
And in the interest of someone desperately juggling search engines terms, such as I had in the quest to find a solution to their problem, I type the following:
Ernie Ball volume pedal taper problem solution
hope this helps someone.
Misplaced Texan
Reverend_Cheese is offline   Reply With Quote
