Old October 21st, 2009, 02:20 PM   #1 (permalink)
LED Issues
Hi,
So I finished building a compressor pedal for a friend last night. It sounds great and seems to work well.
I housed it and hit the switch; the LED shined bright blue for about 5 seconds, sputtered and then shut off. I just kept playing for a while and it came on intermittently.
I then opened her up and measured the voltages. I had 9.33V coming off of the DC power jack, 2.1V at the Anode, and 0V (ground) at the Cathode. I have a 1K Ohm resistor between the DC jack and the LED, which I guess has 7.2V across it. Does that sound right?
With everything still wired-up, I put a green led in parallel with the the blue LED (I just touched the leads together) and the green LED worked. I then put a blue LED in parallel with the original blue LED; in that configuration both turned-on worked for again about 5 seconds, sputtered and turned-off.
I didn't have the energy to get the soldering gun out and just wanted to play some more. When I went to play again, it turned on, sputtered and went off.
Any thoughts? Do blue LEDs need a bigger resistor (or a smaller one)?
Thanks!
joinpobob is offline   Reply With Quote
Old October 21st, 2009, 04:13 PM   #2 (permalink)
CA_Dan's Avatar
From the StewMac website:
To calculate the correct size resistor, subtract the LED voltage from the battery voltage, then divide by the LED’s current consumption (in amps) to give the necessary resistance. For example, a red LED normally runs at 20 milliamps at 2.2 volts. If you use a 9-volt battery you have (9V - 2.2V) / 0.02 amps = 340 ohms. 100 to 330 ohm resistor usually work fine. Depending upon your calculations, you may want to choose a resistor a little smaller to account for the battery running down.
CA_Dan is offline   Reply With Quote
Old October 23rd, 2009, 01:33 PM   #3 (permalink)
I always run LED's at 10mA regardless of the color. With less current, there is less draw on the battery whether it's running down or not. 20mA is close to the Absolute Maximum for a lot of LED's, and 10mA is reasonable. For many, many pedals, most of the battery power used goes for lighting LED's.
If you're using 1K, I'd suspect a wiring issue. Maybe something did not get wired as you intended because 1K should not cause that problem with an LED.
FenderLover is offline   Reply With Quote
Old October 23rd, 2009, 05:31 PM   #4 (permalink)
You can run them even lower. I use super-bright LEDs in my effects and I run them down to even 1 mA. Your luminous intensity will drop, but it's not going to make much of a difference in how bright it really is for this purpose. The lower current you run, the longer a battery will last!
callaway is offline   Reply With Quote
Old October 23rd, 2009, 05:42 PM   #5 (permalink)
dagger4's Avatar
Try for the clear blue ones 20k ohm on 9 volts.
Standard for normal leds is 4.7 k ohm on 9 volts.
Assuming that your wiring is direct from the 3 dpt switch
Chris
Myspace Music:
http://www.myspace.com/chrisschutter
dagger4 is offline   Reply With Quote
9s to 10s set-up issues? Brokenpick Telecaster Discussion Forum 11 September 17th, 2009 12:13 AM
Grounding issues kyle1167 Tele-Tech 10 February 24th, 2009 09:28 PM
Sound Issues Cantom Worship Service Players 9 July 14th, 2007 09:26 PM
Anyone else having issues? tdu Forum Problems & Issues 13 May 29th, 2007 04:26 AM
uh oh...gig issues Mark N Bad Dog Cafe 9 November 15th, 2005 07:12 AM
