Old October 19th, 2009, 04:02 PM   #1 (permalink)
stax's Avatar
Diy Attenuator project
A while ago I built a simple L pad attenuator, which I use occasionally but would quite like to have a go at something a little more professional, I’d like it to be able to switch between 4-8-16 ohms and use it up to my biggest amp, which is a 45-watt pro reverb.
Anyone know of, or recommend any kits, schematics etc.
Thanks in advance
Stax
PS Not sure if this should be in the effects or amp forum as it's literally somewhere between the two?
stax is offline   Reply With Quote
Old October 19th, 2009, 11:11 PM   #2 (permalink)
Check out www.tedweber.com. Under amp kits they have an attenuator kit for 200w amps. They post the schematic on the site. I used their designs for an amp project.
Jimmy Dean is offline   Reply With Quote
Old October 20th, 2009, 10:34 AM   #3 (permalink)
stax's Avatar
Thanks, didn’t see that when I was checking out his site.
Stax
THD attenuator... mrbdxmpl Amp Central Station 6 March 6th, 2009 03:45 PM
Which Attenuator...Or Not? iim7v7im7 Amp Central Station 6 July 13th, 2008 03:42 PM
8 ohm attenuator 16 ohm cab? iowa Amp Central Station 1 February 14th, 2008 04:44 PM
Best Attenuator? WCStevens Amp Central Station 6 January 28th, 2008 08:27 PM
best attenuator furrfurrfurr Bad Dog Cafe 5 July 8th, 2007 07:02 PM
