Old October 18th, 2009, 01:17 AM   #1 (permalink)
emu!'s Avatar
Reducing bass in DIY tube stompbox
a few years ago, I built this:
http://www.dogstar.dantimax.dk/tubestuf/mchowit.htm
It seems to be a little dark. If I want to brighten it up, would I just change the 100uF cathode caps to 25uF???
I also want to add a passive tone control, kinda like on a guitar...one outside lug sent to ground to "roll off" some treble after the above change is accomplished. Where is the best place to insert this tone control into the circuit? I am guessing at the very end, right before the output jack.
Thanks,
emu! is offline   Reply With Quote
Old October 18th, 2009, 01:42 PM   #2 (permalink)
11 Gauge's Avatar
It will still be dark with the 25uF caps, especially because the cathode resistors are big. I would personally drop down to 1uF, and adjust from there.
You can put your treble bleeder after either C6 or C8. But don't put it after R8.
You could also put different cathode bypass cap options on toggles or rotaries. With the right values, the tone circuit probably wouldn't be necessary, and the effect should potentially sound better. I.E. you aren't boosting too much highs only to try and passively remove them down the line.
Reducing superchamp XD volume woobag Amp Central Station 9 July 14th, 2009 12:06 AM
Tube pre amp vs. Tube amp ....for bass batkins The BASS Place 4 February 1st, 2009 11:54 PM
Reducing the weight of my Tele. namelet99 Telecaster Discussion Forum 18 May 1st, 2008 08:44 PM
Reducing Pic Size jumpnblues Bad Dog Cafe 7 August 9th, 2007 05:21 AM
Reducing hum 11 Gauge Amp Central Station 1 June 29th, 2007 10:45 AM
