Bass Accompaniment for I-vi-ii-V?
What would a bass player do during a repeated I-vi-ii-V progression. Would you typically keep it as simple as just playing those four root notes? Or is there a not-too-flashy way of working in a couple of chromatic notes somewhere along the line? Imagine a tune that moves along a bit in a pop or old jazz idiom.
ON HIATUS |
Super Moderator
Depends on the song, of course, but I'd probably do some walking lines (I was gonna tab something out, but my brain refuses to work that acutely yet!).
Cheers, Tim |
Heres a great thread on the Garriton site. Lots of examples.
http://www.northernsounds.com/forum/...ad.php?t=57278
Your attitude will always affect your altitude. |
martini,
That's a good link. I'll try to digest it in small doses over the next few days. I did piano lessons and band in grade school but never went through the whole theory and harmonization study. Now's as good a time as any to get started... Tim, I guess 9am on a Monday morning isn't the best time to ask a bass player to go into exhaustive technical detail. See, I learn something every time I post a question here! Merry Christmas, guys.
ON HIATUS |
If it's jazzy, I'll often walk into some double stops. The classics are the 6th, 7th, 10th & 11th - while holding down the root. Depends on the instrumentation of course. trio setting with a guitar it's easy. Key's or key's & guitar - maybe too much going on down there ... depends on the tune of course
Probably the first avenue to explore with "walking" in this instance is the tried and true approach of preceding the target tones with a note that is a half step above or below the target. When you listen to cool swing, jazz, and blues I-VI-II-V bass lines, this is often what's going on. Vary it up with the moves; if you're a half step above prior to the II and a half step below before the VI, do the opposite next time around, and so on.
I'm a freak for diatonic 10th* intervals and inversions on bass. *Technically, most folks don't acknowledge "10th" as a legitimate musical interval, although I use it all the time. It's a 3rd above the octave. On a four string bass it best lays on the E and G strings. |
#8 (permalink) | |
Thanks! / Tony
{8^)> |
