Old October 28th, 2003, 05:20 PM   #1 (permalink)
Stock neck shim on '83 Jazz Bass (??)
I bought an used '83 USA Jazz Bass about 15 years ago and never had a need to take the neck off. All my neck adjustments were made by taking off the pickguard. Well, I decided to take the neck off and do some cleaning...makes the bass sound better. ;)
I noticed a very thin piece of material that may be a shim. Did Fender put these in as final adjustments?
twangchief
______________________
"If there ain't there oughta be"
twangchief is offline   Reply With Quote
Old October 28th, 2003, 06:12 PM   #2 (permalink)
fenderslaper's Avatar
Yes they did.
fenderslaper is offline   Reply With Quote
Old November 2nd, 2003, 06:00 PM   #3 (permalink)
bluesy's Avatar
I've seen alot of manufacturers across the board use factory shims on both basses & guitars. A much more cost effective option than rematching the body with a different neck (or visa versa).
"You don't get down off an elephant, you get down off a duck."
bluesy is offline   Reply With Quote
Old November 15th, 2003, 11:45 PM   #4 (permalink)
Re: Stock neck shim on '83 Jazz Bass (??)
twangchief
Yes, Fender, and almost every other Bolt On builder has used shims for years and years. Nothing wrong with it, just a better fit between body and neck. Leave the shim in that baby and lay down the LOW END !!!!!!!!!!!!!!!!!! :P
" THE GREASE IS IN THE GROOVE "
51pbass is offline   Reply With Quote
