So, why does a bass sound like a bass?
I guess this is a really stupid question, but I thought about it for a while and I guess I don't really know the answer.
I'm starting from the point of view of a guitarist who's doing some home recording and does not own a bass/bass amp. Also, I've heard that the white stripes song "7 Nation Army"s baseline is actually just a guitar run through an octave pedal (set to one octave low). So I guess I actually have 2 questions: ~does this sound like a reasonable thing to do for home recording? Does anybody do this? ~What makes a bass sound like a bass (As opposed to the first four strings of a guitar? Is it the longer scale? the thicker strings? Also, is my bass player's open E string an octave lower than my open e string? |
[QUOTE=TelZilla;892399] Also, I've heard that the white stripes song "7 Nation Army"s baseline is actually just a guitar run through an octave pedal (set to one octave low).
So I guess I actually have 2 questions: ~does this sound like a reasonable thing to do for home recording? Does anybody do this? [\QUOTE] sure - if you want to sound like the white stripes ... If you want it to sound like electric bass, you probbaly want to purchase or borrow a bass. The FB layout is the same as standard tuned guitar and the fingerings are typically easy. The tough part with bass, particularly for guitarists is knowing when no to play, when enough is enough - the borderline to 'too much' land. You could take the aproach above - the guitar through an octave thingy - for a demo, no problem. Anything beyond that is going to require some different approaches or it could get kinda boring. Personally if I were trying to fake my way through bass lines - I would go synth. An 80's Korg Poly 800/Poly 600, etc will lay down a hellacious bassline and key bass isn't all that hard to learn. It can also be programmed and sequenced more easily. |
As I think about this more, it's a chicken and egg situation, right? Like, if you tried to tune your guitar an octave low (i.e., like a standard scale bass), there would be no tension on the strings, so the scale has to be longer to accomodate the lower note.
But I still have a question about the string gague: Say I put a neck on my guitar that was the scale of a bass neck (this is a rhetorical question, of course) and had a .052 string that was long enough to fit the neck. If I tuned it correctly, would it sound like a bass, only quieter? Or is there something about the gague of a bass E string (a .110, say) that is integral to acheiving that particular pitch? |
#6 (permalink) | |
[QUOTE=4mal;892479]
And I have lots more guitar crap to buy (mainly tube amps) before I buy a bass or a keyboard... |
#7 (permalink) | ||
Super Moderator
But this doesn't have to be a theoretical discussion -- you can test it yourself with any electric bass. Hope it helps, CS
"I go online sometimes, but everyone's spelling is really bad. It's depressing." – Tara, from "Buffy the Vampire Slayer" "It was born at the junction of form and function." – Bill Kirchen, from "Hammer of the Honky-Tonk Gods" |
#8 (permalink) | |
So that also means the string tension on a standard tele or Strat ( 25.5" scale) is just slightly lower than on a Les Paul ( 24.75" scale), assuming the same strings are used. Weird... |
#10 (permalink) | |
Super Moderator
Cheers, Tim |
Understanding why a plucked string sounds the way it does is pure math and physics..
http://hyperphysics.phy-astr.gsu.edu...es/string.html |
