Electronics Buzz- Warwick Bass
I'll post here first...
I have a Warwick Corvette Bass that I'm trying to repair for a friend....It has 3 pots......volume, tone, and blend (fader) for the pickups....All grounds look good, but when you touch the blend pot(metal knob) it buzzes like crazy! Like a ground to the hot lead buzz.....any ideas.....????
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. www.neonjones.com |
active or passive ? If it's active, the pre is likely bad. I've seen the internals of one warwick and the pre was a monster circuit board with the pots hard mounted. If it's one of those... time to scrap the pre ...
Passive.....
well it could in fact be a ground to hot. That should be a stacked Pot is there anything like a solder drip jumping the two pin sets ? Where is the bridge ground connected.
I don't know how far you want to get into this but - I would do a diagram and then un-wire. Replace the stacked pot and wire it vol/vol/tone in the standard jazz wiring scheme. If you get no buizz - get a replacement for the stacked pot. It's that old process of elimination thing. |
This is the layout....
Specifics: 2 Passive MEC Jazz pick-ups. (This model is completely passive.) 1 Volume Control (Part #M83500 - 500K) 1 Pick-up Pan Control (Part #M86252 – 220K) 1 Tone Control (Part #M81500 – 500K Log) Schematic http://www.warwickbass.com/schematic...crvttepass.gif
