Old May 26th, 2012, 02:58 PM   #21 (permalink)
Super Moderator
Tim Armstrong's Avatar
I'll add a recommendation: I'm currently gigging with a Hartke LH500 head, which has a tube preamp voiced like a blackface Fender and a 500 watt solid state power amp. It sounds just like my old Fender Bassman head, but has a lot more power. I'm just plain in love with it, can't get a bad sound from it, and best of all they cost $350 shipped from any of the usual online sources (MF, Sweetwater, etc).*Oh, and the LH1000 (a thousand watts) is under $500, too.
Tim
Old May 26th, 2012, 03:03 PM   #22 (permalink)
Warm Gums's Avatar
I wouldn't discount a b series Ampeg ; they are rated conservatly, project well, and with a high efficiency speaker in the box (and depending was size room you are in,) the 15 ( 30 watts or so) could probably cover the gig,as long as the drummer was using jazz size drums with traditional heads like the Remo ambassador or fibreskins.
They were a popular club amp BITD and were often miked for bigger gigs. I used on in college in a 250 seat hall for jazz band and it was right there.
The 18 is 60 + watts and is a great gig amp for a traditional bass sound, harder to find though.
Alas all of these are kind of $$$ now , the SB 12 is less $ but is probably a little under gunned for any thing but a small room, semi acoustic type of gig.
Warm Gums is offline   Reply With Quote
Old May 26th, 2012, 03:12 PM   #23 (permalink)
bigmuff113's Avatar
Tim
+1 meelion. My dad has the LH1000 and 2 15 cabs. Amazing big fat cleans. He lets me use his LH500 with 410s and I get the best sludge, but I use a rat for distortion because it is super clean
bigmuff113 is offline   Reply With Quote
Old May 26th, 2012, 03:17 PM   #24 (permalink)
Rod Parsons's Avatar
A blackface or silverface Showman amp with one or two 15"s is huge... The showman original "ported" cabinets are the best.
I put a "paper in oil", .015 cap in my Telecaster. It sounds great, because the oil lubricates the electricity and makes it go faster.
Rod Parsons is offline   Reply With Quote
Old May 26th, 2012, 03:21 PM   #25 (permalink)
jefrs's Avatar
Nobody mentioned the Marshall Super Bass, this evolved from using the Super Lead head (100W plexi) into a bass cab. The reason I ended up with a Super Lead (gone) is that the bass player left it with me.
Old May 26th, 2012, 04:23 PM   #26 (permalink)
Just curious why this thread was moved from the Amp section as it is about bass amps not bass guitars.
jh45gun is offline   Reply With Quote
Old May 27th, 2012, 01:27 AM   #27 (permalink)
Because this is the Bass Place.
I suspect most of the bassists who post here wouldn't see it if it were in the amps section.
Dave W is offline   Reply With Quote
Old May 27th, 2012, 09:32 AM   #28 (permalink)
OK but there is plenty of bass amp talk at the amp section this is the first time I ever seen a thread about a bass amp moved out of the amp section. Not being critical just curious the reasoning behind the move. You look at every post it is amp talk not guitar talk. Just wondering why.
Old May 27th, 2012, 10:38 AM   #29 (permalink)
Super Moderator
I moved it (and have moved plenty of similar posts in the past) because this is a subforum for bassists, and we talk about all kinds of bass gear here, amps included!
Tim
Old May 27th, 2012, 10:46 AM   #30 (permalink)
Beatbx's Avatar
As an audience member, V4 through a 4x12 is one of the best bass sounds I have ever heard.
Beatbx is offline   Reply With Quote
Old May 28th, 2012, 04:02 AM   #31 (permalink)
ok Tim first I have noticed it. I have seen other bass amp threads that were not moved so just wondering .Thanks for the reply.
Old May 28th, 2012, 04:51 AM   #32 (permalink)
Joely's Avatar
Hiwatt dr103 if you can get a 70's one.
Joely is offline   Reply With Quote
Old May 28th, 2012, 10:02 AM   #33 (permalink)
Warm Gums's Avatar
Oh and you could always consider a 4x10 Bassman, the original RI are pretty inexpensive 2nd hand, and in the right situation can sound very good.
A friend of mine plugged a Squier CV "original" p bass that I had knocking around, it had a Duncan "bass line" pu in it ( the old school one..not the high out put) in to one and it just flat out boomed, perfect for Rock and Roll, old style R&B etc. again the PA is your friend in bigger rooms, and you might want to use the ss rectifier,and this won't fly with big drums or too much guitar amp.
But as a complement to a DR or a AC15 it's perfect.
Old May 28th, 2012, 06:30 PM   #34 (permalink)
Super Moderator
The biggest problem with a 4x10 tweed Bassman is that it has an open-back cab with guitar speakers (that like to blow when you play loud bass) in it, and isn't really very good for bass at any real volume...
Tim
Old May 28th, 2012, 10:01 PM   #35 (permalink)
Warm Gums's Avatar
Tim
Well like I said " in the right situation"..
The OP was a little vague as to what he means by club, and exactly what kind of volume he was looking for, he also didn't mention the style of music.
I have seen any thing from a small bar with 6 tables and a couple of booths to a hall with the same but a floor that can hold 500 people called a club.
The smaller amps can handle the first but not the second...given adherence to some of the parameters on other instruments I laid out.
IMHO most of the bands that I hear in dining establishments play far too loud, their sound bleeds out of the stage/ dance floor area, and makes conversation difficult, in the rest of the building. The bulk of the problem is modern drums that over-project and have everybody especially the bassist playing catch up. Modern rigs require a lot of power to keep up with those tubs and are often "edgy" and don't sit well which I assume is the reason the OP is considering tubes.
Neighborhood has a small club, bar with 50 seat dining area, on Fridays this winter they tried a house reggae band that was way over amped for the space, big SWR rig on the bass.
Now I like a sold bass sound when playing reggae, it's part of the deal, but this was over the top. They didn't last too long.
Sat was a small "early music " combo..lots of 50s 60 s stuff, sounded excellent, B-15, sat in the mix great, ocassionaly I catch them in a smaller space, tweed Bassman was in use, no problem, guitarist often uses a brown Princeton...
You don't always need thunder bass, I'm a big fan of " presence bass" where you know its there, but it's not overly obvious. I often do small "back ground" gigs with my Beatle bass and a La 8, we are well received, and no one has ever asked or commented about the "lack of bass" I also don't have the phobia that many do about miking the bass. I wouldn't mike a big modern rig with lots of transients, but a round warm sound from a vintage combo is a perfect candidate for a mic, the AKG bass drum mike is great on the b-15.
With a bit of thought and planning you can really get some nice solid sounds out of vintage bass gear, it will require the cooperation of your bandmates, but the rewards are worth it.
Old May 29th, 2012, 12:32 AM   #36 (permalink)
There's no right situation that would justify the use of an open-backed cabinet for bass. It's not about volume or "thunder bass" -- it's about accurately reproducing bass frequencies, which you can't do with an open-backed cabinet. You can't get "presence bass" or a solid bass sound when low frequencies cancel each other out.
Old May 29th, 2012, 07:17 AM   #37 (permalink)
Warm Gums's Avatar
That's your take on a bass sound and if it works for you and gets you paid that's great
However...
People actually used the open backed Bassman for bass for many a year, was the Ampeg superior? Sure in many ways, but the open 4x10 (compromise or not) was the sound of many bands, just as a string bass with a "Elvis" mike somewhere near it is a legit sound..no "accurate reproduction of bass frequencies" there.
I'm privileged to often work with folks are willing/looking to experiment and try different things (I sometimes use open back guitar amps for bass in the studio)and the concept of "no" just dosen't get the job done.
Physics is fine and you need to know the rules before you can break them, but at the end of the day what my job is "about" is coming up with something that works for the client, either live or on a track.You don't always need full reproduction of low frequencies for that, you just need a cool sound that makes people happy.
Since the OP didn't put anything off limits, I threw out some funky alternatives that might just be the ticket....
Old May 29th, 2012, 08:05 AM   #38 (permalink)
Paul in Colorado's Avatar
Originally Posted by Arbiter View Post
Depending on how loud you'd like to get, an Ampeg V4B might be the way to go. I can hardly lift mine anymore - weight is a real issue with any tube bass head - but it has the fattest sound I've heard out of any bass amp ever.
I haven't looked in a while. They used to be pretty cheap.
I used to have an Ampeg V-4B. I wish I'd never sold it. I bet it'd sound awesome with a cab with a 15" JBL or EV bass speaker. Old school for sure, but great tone.
"Can y'all play some Skynnard? Y'know, like 'Stairway to Heaven?'" -Drunk cowboy at Trail Dust Days, Pine Bluffs, WY
Old May 29th, 2012, 08:23 AM   #39 (permalink)
Warm Gums's Avatar
The bassist in "Too Much Fun " used a V series Ampeg with a modern cab at one time. Interesting rig, of course there s no place to hang your towel;-)
IIRC it was a 4 x10, I agree with Paul that a good old school 1x15 with a decent speaker would be a " best of both worlds " situation.
Old May 29th, 2012, 04:59 PM   #40 (permalink)
Cadfael's Avatar
25 years ago our bass player had a used Marshall 100 Super Bass with a 4x15 cab.
Transport was horror ...
When he bought an H|H amp, I bought his bass Marshall for m Telecaster guitar.
I wouldn't play a tueb amp anymore because of the weight. But I think the A&O is the efficiancy of the cab.
With a good cab and a roadie I would play a 135 Bassman. Or maybe I would modify my Fender Super 60 guitar combo (1989 red knob) into a bass head. Even together with my (Rockinger) Telecaster guitar the combo has a hell of bass punch!
Once I played guitar in a band and a bass player played a 50W Engl amp (over a 15" cab). The amp setting was a little bit "unusual", but thesound was very good!
Cadfael is offline   Reply With Quote
