Old August 3rd, 2011, 04:11 PM   #1 (permalink)
Just curious: has anyone built this yet?
Jazz Bass with a single MM in the sweet spot and passive electronics, most likely swamp ash and maple neck. Something I have in mind as a project. Mostly curious about the passive MM HB in this application and position. The goal is pretty much a "P-Bass with balls", a sound somewhere in between the P-Bass and J-Bass bridge sound, with the added guts and growl derived from the humbucker.
John R. Frondelli
"Mediocre" is the new "Good"
jrfrond is offline   Reply With Quote
Old August 3rd, 2011, 07:08 PM   #2 (permalink)
fenderslaper's Avatar
Sounds cool. Go for it!
fenderslaper is offline   Reply With Quote
Old August 4th, 2011, 07:51 AM   #3 (permalink)
losergeek's Avatar
This is exactly what I was hoping to get from the Blacktop Jazz bass. I've also thought about replacing one of the single coils in my J bass with a MM style pickup
losergeek is offline   Reply With Quote
Old August 4th, 2011, 04:05 PM   #4 (permalink)
The pup location should be moved south a little to assist
this kind of sound.
I got this effect in a different way.
I put a 22 fret Pilot neck on a P bass body. This moved
the whole neck 5/8ths inch north. That caused the bridge
to move 5/8ths inch closer to the pup.
Result is a neck thinner than a Jazz or even a Ibanez and
the upper strings are much easier to access. The sound is
more punchy and aggressive than a P bass. But it still sounds
nice and bassy if I pick close to the neck.
There is a small gap at the bottom of pocket, but it is not
noticeable,
I'm working on them holes,
Tabdog
tabdog is offline   Reply With Quote
Old August 4th, 2011, 04:35 PM   #5 (permalink)
4mal's Avatar
Try a Lakland 44-02. It has the Bart preamp but has passive mode as well. The neck is in the 1 5/8ths range that to me is a real sweet spot.
4mal is offline   Reply With Quote
Old August 5th, 2011, 10:36 AM   #6 (permalink)
Yeah, but this is my own build. I already have it priced out (around $500) and ready to order parts. This is what's going in:
- Warmoth J-Bass body, swamp ash
- Allparts JMO J-Bass neck
- Gotoh 201 Bridge
- Hipshot HB2 machines with a BT2 Bass Extender
- MM HB bass pickup (brand yet to be determined, but I might start with GFS Alnico) with series/parallel/split switch and passive volume + dual-action tone
- Side jack in an Electrosocket
No pickguard, natural nitro over TruOil on body and neck (perhaps only TruOil on neck with nitro headstock). Nice, simple, elegant. If I decide it needs to be active, there's plenty of room in the rear control cavity.
John R. Frondelli
Old August 6th, 2011, 09:25 AM   #7 (permalink)
- Gotoh 201 Bridge
OK,
But I don't see how that equals;
I see two different animals here.
Tabdog
Old August 6th, 2011, 04:43 PM   #8 (permalink)
Originally Posted by tabdog View Post
OK,
Tabdog
Not at all. I am basically taking a single-pickup Fender platform (J or P, it really doesn't matter) and substituting a higher-output humbucking pickup for the P pickup, and moving it about 1.5" back toward the bridge for more "cut", while the increased output increases sensitivity and "guts". Sounds like a plan to me.
Ironically, I saw this bass in Sam Ash today: http://www.bcrich.com/shape/zombie/bass/20
While I think it is one of THE most hideous things I've ever seen (and dared not let anyone see this ol' guy playing it), it is essentially what I want to build with a different shape, and I liked the sound alot. I will be wiring the pickup for coil switching capabilities, but essentially, it's what I want sonically.
John R. Frondelli
Old August 6th, 2011, 04:49 PM   #9 (permalink)
JimmyJam's Avatar
@ jrfrond:
Wow
That is hideous, but if you can make it work; then more power to you.
I bet it would sound great. Just the appearance may be questionable.
JimmyJam is offline   Reply With Quote
Old August 6th, 2011, 08:55 PM   #10 (permalink)
Originally Posted by JimmyJam View Post
@ jrfrond:
Wow
Well, THAT appearance may be questionable, but I am building it with a J-Bass body and neck. Quite a different story, don't ya think?
John R. Frondelli
Old August 25th, 2011, 05:04 AM   #11 (permalink)
davmac's Avatar
I've not long finished making this one. Not a jazz body, but I'm really happy with how it turned out and I just love the MM pickup.
And a brief demo of the sound (with construction pics). Apologies in advance for the playing but I'm used to having two more strings.
davmac is offline   Reply With Quote
Old August 25th, 2011, 09:46 AM   #12 (permalink)
I think G&L made something similar, either L-1000 or L-1500.
dlb1001 is offline   Reply With Quote
