Old October 2nd, 2009, 10:34 PM   #1 (permalink)
Bass Cabinet
Does anybody have the schematics to build a 210 cab? I want to build a cab that has two chambers, ported and has a horn. I haven't been able to find anything yet. Any help would be great!
unclemartha is offline   Reply With Quote
Old October 3rd, 2009, 11:14 AM   #2 (permalink)
You might try posting a question on this blog:
http://bassguitarblog.com/2008/12/cl...abinet-design/
You can also wander over to Talkbass since there are guys over there looking for plans:
http://www.talkbass.com/forum/showthread.php?t=491220
dlb1001 is offline   Reply With Quote
Old October 3rd, 2009, 11:57 AM   #3 (permalink)
Keep in mind that when you build a ported or sealed cabinet, if you want it to sound good, you need to design it to fit the properties of the particular speakers you'll be using.
Dave W is offline   Reply With Quote
Old October 3rd, 2009, 01:42 PM   #4 (permalink)
4mal's Avatar
Why a 2x10 ? If you want a full range 2 way rig and you have the power to drive it, go to TB, amps forum and reserach the fEarful 12+6. I've spent a little time with one of those and it's impressive. Really impressive. After I get a 15 + 6.5 done, I'll probably do a 12+6, sell off everything else and call it good... amazing cab!
I'e been following driver development and doing DIY cab's designs for a bit All the good stuff is going down with 12's and 15's. 10's are pretty much dead from a new development standpoint - at least until next years namm...
4mal is offline   Reply With Quote
Bass cabinet choices? Tele295 The BASS Place 23 August 10th, 2009 11:10 AM
el deville's cabinet, too much bass? scoots Amp Central Station 1 August 12th, 2007 07:29 AM
Dumb question of the day: What jack to use in a bass cabinet? sean79 Amp Central Station 10 July 13th, 2007 01:02 PM
Is building a bass cabinet really this easy? sean79 Amp Central Station 17 July 1st, 2007 12:47 AM
Advice needed on Bass Cabinet and Head ashtray The BASS Place 24 November 16th, 2005 01:26 PM
