Old May 7th, 2003, 02:43 PM   #1 (permalink)
Tone Talk
I have two basic settings I use on my Jazz Bass: either both pickups on full, or the neck pickup backed off just a bit to induce more growl. I keep the passive treble circuit (the tone control) rolled off just a bit to cut down on extraneous fret noise. I am curious about what other bass sounds you guys have found on your basses, either Jazz or not. I would like to get a range of sounds that I can get from my Tele, only in the bass format. I would like to be able to go from P-Bass sounds and McCartneyesque Hofner sounds to woody growl like what you hear on Meters records. Any thoughts?
Born in Chicago is offline   Reply With Quote
Old May 7th, 2003, 03:30 PM   #2 (permalink)
IMHO it's hard to get a p-bass sound from a j-bass. As I hear it, the trademark j-bass growl with both pups full on is a cut-midrange sound. it's a great sound but diffeent from the P-bass which has a humbucking pickups with a lot more midrange bark to it. I can never get j-basses to sit right in the mix, whereas for me p-basses are right there and solid all the time.
I like flatwounds (TI Flats) fingerstyle, and the ampeg sound, which is heavy on the low midrange
maxvintage is offline   Reply With Quote
Old May 7th, 2003, 03:37 PM   #3 (permalink)
Bob Rogers's Avatar
One of the advantages of using a J-Retro with a J-Bass is that you can boost the low mids and get the J-Bass to sit in the mix in almost the same way as a P.
I have a J-Retro on my fretless J. I usually play with both pickups balanced and a bit of boost in the lows and upper mids.
I guess that if you want a wide range of sounds a J-bass with a J-Retro has them. Of course, if you are like me and 80% of the time you want the sound of a P-bass with TI flats....
Bob Rogers is offline   Reply With Quote
Old May 7th, 2003, 05:11 PM   #4 (permalink)
Every tried a pressure wound string to reduce that finger noise, but retain that round wound liveliness with just a hint of flat wound thump? I absolutely LOVE the GHS pressurewounds. Heard good thing about the Rotosound 55's, but never have tried them. I believe the SIT Silencers are similar too.
brock29609 is offline   Reply With Quote
Old May 8th, 2003, 09:07 AM   #5 (permalink)
Good info
Hey guys, thanks for the input. I have been using La Bella Deep Talkin' Flats. I think I'll give the TI flats a try. Maybe the P-J pickup combo seen on a lot of basses is a good combination? Or is it difficult to integrate the two pickups? Not sure if I want to go the active J-Retro route. Active electronics can only boost and cut what is already present in the sound of pickups and the instrument, right?. I'm using the fabulous Aero pickups in a lightweight swamp ash body.
Old May 12th, 2003, 07:21 PM   #6 (permalink)
4mal's Avatar
The P/J is extremely versatile. Depending on the set you pick, the P can over power the J though. I'm using Duncan's vintage in one I just built and they seem to blend nicely. Not as Gucci as the Aero's though ...
I'm thinking about a call to Lawrence and see what they can do about balance for my next one.
I would have to say that the hofner is a sound that pretty much needs a hofner or maybe another hollow body to get. There is some *air* in that sound that a plank just doesn't get. The P&J basses regardless of pickup have a whole lot more substance to them. Kind of like comparing a 335 and a Tele, both cool but complimentary, not competing for hte same space.
4mal is offline   Reply With Quote
