How much buzz on your bass?
Hey there
My MIM Jazz is doing well but I've been unable to completely dial out fret buzz on the E and A strings. How high do will you guys adjust the saddles before you just give up? Is buzz more normal on a bass than guitars? |
#2 (permalink) | |
However, E and A strings do usually need a bit more string height, all other things being equal.
Data, not opinions Help, not "humor" Information, not conversation Signal, not noise |
#4 (permalink) | |
I wrenched on the guitar for some time trying to remove some of the bow. I think that I have the relief at a decent point. Probably a fret issue then? Have others had a similar problem? Is that "growl" pretty normal on a bass? My biggest problem with it is that I play at a low volume and get to hear all of that racket. It doesn't sound so nice when it isn't coming out of a speaker. |
#6 (permalink) | |
Unless you have extremely true fretwork (get a fret rocker and find out) and play very lightly, you need some relief in your bass's neck or you'll get string noise. Unless there's something seriously wrong with the basic build (and there frequently is), there's never a need to shim a neck. I'm still guessing that the E and A are too low for your style of playing.
It's a MIM ? Check for fret level first, then relief. No real empirical eveidence but I *think* I get better tone with the strings a smidge higher than their absolute lowest. Not high enough to cause intonation issues but a smidge up. Of course it may have as much to do with my hands as anything.
One advantage to having your strings a little high is that it will tend to slow you a bit. Really makes you plan that next fill and sometimes go - ah, tht fill isn;t really necessary and sometimes that means a fatter, tighter pocket ... Once in a while I need the reimnder... Overall I feel my action is pretty low - just not necessarily all the way down there if you know what I mean. I took the same approach on my Tele. I had it setup to Bill Kirchen's specs and that turned out to be slightly higher than I generally had set it up in the past. I like it it that way but then I'm a bassist hwo plays guitar not the other way around ... |
Moderator
I've found that different strings like different heights, too. For example, I can lower the GHS Precision Flats a bit more than I can TI Jazz Flats (a lower tension string).
Some strings just need more room! Tim
http://www.moodswingers.org |
Funny that I don't mind a little buzz on my guitars, but can't stand it on a bass! But I do like low action on a bass. I've always done my own set-ups, guitar expecially; and the guys that I have done set-ups on thier basses have been amazed at how well I can get thiers to play! But to me, a bass should be pretty much buzz free, but with a very comfortable action/playability. But then, every player has his own style/technique/requirements.
Really? I always thought P-Bass growl is a function of the pups, amp and playing style. My 86-87 MIJ P-Bass has what I'd call a medium action, just a bit of relief and no string buzz whatsoever. And, it growls quite menacingly.
mud
MudBean Music Nekkid Bart: "This is the worst day of my life." Laffing Homer: "Worst day SO FAR!!" |
I use this as a basic guideline for setups:
http://www.box.net/shared/mzlz0b82py Assuming you have level frets, buzzing should be minimal or nothing at all. |
My Rick is a bit buzzy, as well (I suspect a worn-out nut), but it feels pretty good, so I haven't messed with it thus far...I think I feel a pro set-up coming soon, cause it's been a long time (I check it out once a year or so myself) but it might just be time for a pro to have a look-see.
A little buzz isn't hurting anything, though it is distracting when practicing without amplification, innit?
42 |
#16 (permalink) |
OK, I was just downstairs with my MIM J, and had a minor brainstorm. Well, drizzle, maybe. Ok, more light a fog, but here's what I remembered: The E & A strings don't have a lot of break angle over the nut. I have to remember that I need to wind 2 or 3 wraps around the tuner post to force the string down far enough to avoid rattling, just like the E/A strings on my tele.
Happens on my P bass, as well.
42 |
| Need 50's p-bass (tele-bass) Drawing/Tracing | axmaker | The BASS Place | 23 | June 11th, 2009 04:29 AM |
| '51 P-bass (tele bass) build: Pics Inside! | ccrnnr9 | Tele Home Depot | 5 | April 7th, 2009 07:42 AM |
| Low action Buzz, or High Action No buzz? | JohnnyRebKy | Telecaster Discussion Forum | 6 | January 10th, 2009 10:29 AM |
| Electronics Buzz- Warwick Bass | guitarzan13 | The BASS Place | 4 | April 26th, 2007 04:23 PM |
| Any cool starter bass books/DVDs for young beginning bass player? | sean79 | The BASS Place | 5 | December 16th, 2006 10:32 AM |
