Old June 26th, 2009, 05:42 PM   #1 (permalink)
maches's Avatar
Neck Gap Question
I refinished and stained an Ibanez bass that had a very THICK finish before, and when I put the neck back on there is a gap about 1/10" where the last fret makes contact with the body. Am I going to have to fill the gap, or should I be okay?
maches is offline   Reply With Quote
Old June 26th, 2009, 05:47 PM   #2 (permalink)
You should be fine - lots of guitars, including nearly all arch tops, have a gap like that.
dan1952 is offline   Reply With Quote
Old June 26th, 2009, 05:50 PM   #3 (permalink)
xrolandtx's Avatar
Im pretty sure you will be fine. many guitars, including some strats with the fretboard extension and many of the gibson sg bolt on neck guitars have gaps just like that if not worse!
____________
Fender Baja Telecaster // Fender 69 RI Thinline Mahogany // Orange Rocker 30 Combo // Parker Nitefly M
xrolandtx is offline   Reply With Quote
Old June 26th, 2009, 06:02 PM   #4 (permalink)
maches's Avatar
sweet, that's what I wanted to hear. Going to string her up now.
Old June 27th, 2009, 06:27 PM   #5 (permalink)
The sound of the bass will be different, possibly better.
The overhang is fine.
Are you going to oil finish that?
Sl8e is offline   Reply With Quote
Old June 28th, 2009, 04:28 AM   #6 (permalink)
casterway's Avatar
Check out the gap/overhang on a Gretsch hollowbody sometime!!
If Meg White can call herself a musician, then so can I.
casterway is offline   Reply With Quote
Old June 29th, 2009, 07:22 AM   #7 (permalink)
Who is this Gretchen and is her gap neck width?
Should neck/bridge output numbers match (neck HB question)? sean79 Just Pickups 5 January 21st, 2009 12:37 PM
neck re-set question telemania Tele-Tech 10 September 1st, 2008 02:21 AM
New Guy Neck Question drum1mike Tele-Tech 0 May 10th, 2008 01:28 AM
Question, please help! Squier Affinity Stock Neck Vs. Duncan Vintage Tele Neck bendecaster Just Pickups 2 December 4th, 2007 09:35 AM
USACG: The 54 neck question & truss rod style question boneshaker335 Tele-Tech 1 March 9th, 2006 05:57 PM
