#41 (permalink) | |
i looked at the gfs wiring diagram. you can use the tele blade to do a coil tap, and a pickup "off" option like you wanted. position 1: humbucker position 2: single coil (coil tap) position 3: pickup "off" green is hot, put red/white together, and black is ground. |
#43 (permalink) | |
Moderator
Tim
http://www.moodswingers.org |
#44 (permalink) |
I love it! I'm a newbie here, so if I step on any toes my apologies in advance. Let me know and I'll delete the pic. No intention to hijack. I did this same thing for my "now" exgirlfriend's daughter as a Xmas present. She's into vampire's and hangs with the goth crowd so I called it the Emocaster. I used the original pickups and didn't have any problems. I chopped off the back of the tele bridge plate and just installed the same bridge u have. I used a Rondo sx 30" scale neck. It's fun to play and really sounds great. Take a look.
You didn't plan to fail, you failed to plan. |
#45 (permalink) |
Moderator
That's VERY cool! No problem with hijacking, we do it all the time around here!
And welcome! Tim
#46 (permalink) | |
#49 (permalink) |
Moderator
Okay, got some more work done on Hoss!
So here's the pickup, next to the existing Tele pickup hole (pardon the fuzzy focus, I think there wasn't enough light): ![]() Now, I don't have a router, but I DO have nice sharp wood chisels, and I used to do a lot of mortise work installing door locksets, so I'm not afraid of doing a little cutting with a chisel. The picture I took of the chiseled-out hole is way out of focus, but here's one of the pickup installed: ![]() And here it is strung up: ![]() I wired up the pickup as suggested above, but am getting nothing, so I reckon I need to spend a little more time figuring out the wiring! Tim
#50 (permalink) | |
#51 (permalink) |
Looking good, Tim. Nice chisel work there. Hope you get the wiring figured out - that things needs to be played. Doesn't quite match the pink one though...
Every now and then I know it's kind of hard to tell, but I'm still alive and well. |
#52 (permalink) |
love it tim!!!
www.myspace.com/giginthesky |
#53 (permalink) |
Moderator
Well, after giving it a little bit of thought, I realized I didn't need or particularly want the single-coil sound, and if I wanted to kill the output, I could just turn it down, so I wired it up like a P-Bass and bingo! Great tone!
I did a quick setup, and I'm gonna gig it tonight!!! I will report the results later. Tim
#54 (permalink) |
Moderator
I'm back from the gig, and IT ROCKED!!!!
It took me a few songs to dial it in with the amp, but man-oh-man, once I did, I started grinning from ear to ear! Great growl, great note definition, really nice tonal range to the pickup, bass balanced beautifully, played like butter! I couldn't be more pleased. Well, except that it's significantly heavier than my SX P-copy... But it wasn't a man-killer, so I reckon I can live with it! I am soooooo happy! Tim
#55 (permalink) |
Nice to hear Tim. If you ever get the ability to get some sound clips together please share! I am interested in hearing this thing growl. Hopefully my TB build is only 3 weeks behind yours!
~Nick |
#57 (permalink) |
Moderator
Personalized Hoss:
![]() ![]() Tim
#60 (permalink) |
Moderator
Naw, I'm a set-it-and-forget-it kinda guy, having more options would just befuddle me!
Tim
#64 (permalink) |
I'm building one of these.
I saw one on this board. The guy sunk a short scale on a tele guitar body. Anyway, I was wondering if I should buy a gfs lipstick pickup or a 51' duncan. The lipstick would look real cool but would it sound good? I'm getting a esquier pick guard to cover the front pickup gaps. It should look stock when it's done. |
#65 (permalink) | |
Moderator
I can't say enough good things about the big honkin' GFS Music Man humbucker copy in this bass. Tone-a-licious! As you can see in the pictures above, I put an Esquire pickguard on Hoss, and it looks great! Tim
#67 (permalink) | ||
Moderator
Here's an earlier post that kind of shows all this: Quote:
#68 (permalink) |
That is way extra cool. Looks like the metal doodad on the side of the lower bout is from a revered, no? where can ya' get one of those? I've had an idea to clone an old style rev with the blue boomerang formica. Trouble is I can only find the formica as a special order in an 8x4 (or so) sheet, way more that I need and way more that I want to spend.
No hurries, No worries. |
#69 (permalink) | |
Moderator
Tim
#70 (permalink) |
Thanks Tim, based on this pic and comments in the thread where I found it, that is exactly what rev used ;)
hey, what's the distance from the face of the nut to the first fret on the musicmaster?
#71 (permalink) | |
Esquire
To see a pic of this bass go to : http://www.myspace.com/slatersgreatesthits go to "View My" "PICS". click on Slater's WMD'S. 51' Esquire tenor bass. I'm going to tune this one C-G-D-A , I'll use an octave under effect when using it in order to carry the band. It's a specialty item. [the insert a pic thing doesn't work] |
#72 (permalink) |
Moderator
My niece took some pics of us playing this last weekend, so here's Hoss in action:
![]() ![]() ![]() Tim
#76 (permalink) |
I can't seem to get a url from my myspace to stick here.
http://www.myspace.com/slatersgreatesthits look in pics. WMD's... |
#77 (permalink) |
if fender only knew... i wouldn't have to build one myself. HOSS truly is one of the nicest basses i've ever played.
#78 (permalink) |
Moderator
I gotta see if I can get USACG to make Mustang/Musicmaster Bass necks, betcha I could build and sell 'em!
...naw, sounds like work! Still, gotta say, I'm still ridiculously happy with this thing. Thanks yet again to rhomco for inspiring it with his extremely cool thinline short-scale bass! Tim
#79 (permalink) |
like i boasted to you 10 times, tim... it feels nothing like a short or medium scale bass. and what strings are on HOSS??? they gave it a fretless feel and sound. the GFS MM pup was the final stab to my heart, though. i can't go on living without trying to build a HOSS.
#80 (permalink) |
Moderator
I think that '73 Fender Musicmaster Bass neck is just profoundly good. I know it feels amazing to my hands. And the GFS Music Man copy pickup is just so damn full sounding.
The strings are GHS Precision Flatwounds, and yep, they feel amazing, and have both thump and some piano tonefulness to them... I have another '73 Musicmaster Bass neck that needs a fret job, and I'm seriously thinking of getting a thinline body and doing another bass... Tim
