Old January 31st, 2009, 12:37 PM   #1 (permalink)
Tube pre amp vs. Tube amp ....for bass
I seem to notice that guitar players prefer tube amps. I also notice that bass players seem to opt for tube pre amps with solid state amps. What's the reasoning for this? Weight would be my only guess.
batkins is offline   Reply With Quote
Old January 31st, 2009, 01:45 PM   #2 (permalink)
Bluesbob's Avatar
Ratio...
Power/weight ratio... In fact, the only reason I enjoy playing through my 300-watt SVT is for the tone, when it's being pushed slightly into overdrive and the tubes start to saturate and compress. With a closed-cab 6X10 or 8X10 - that's the ticket.
But I don't want to lug around 100+ lb. cabs and 90 lb. heads. One time I did, but no more. So to get the same SPL's and have some headroom left over for tone-shaping and punch I use an 1100-watt solid state amp with a compressor and pre-amp tube. Even with a wireless, tuner and 8-outlet surge protector in a 6-space rack it all weighs in at a little more than half the weight of the tube head - without the rack and accessories!
All that wattage is necessary to get the maximum SPL's (and tone, punch, projection, etc.) out of a lightweight but highly efficient 4X10 that weighs less than half of the large cab. I can get close to the sound I love with only half the weight.
Not that anybody but us bass-players cares, but the world of bass-guitar is as progressive as any part of music, while as a guitar-player I gotta say my tube amps do everything I need them to. But that's just me. Lotsa guys like modeling amps, too.
What, me worry?
Bluesbob is offline   Reply With Quote
Old February 1st, 2009, 01:32 AM   #3 (permalink)
Thanks for the info.
It does make me feel a bit better when I'm on the right track!
Old February 1st, 2009, 03:24 PM   #4 (permalink)
4mal's Avatar
A lot of the nuances of tubes are not well represented in the bass frequency range. The biggie - that power tube compression thing is about the only advantage I hear and it takes a beheamoth of an amp - the SVT to get it at strong gig volume.
There is a very fine line between just enough of that and too much as well. We've all heard the small guitar amp that just sings when it's in it's range - and sounds kinda flat under the operating range and just fizzy when being run above it ... to my ear, it's the same thing but at a higher power level for tube bass amps. I detest pre-amp tube grind - it is jut not a substitution for what happens in a hot power tube. Not even close...
There are a few designs out there that incorporate tubes that sound great but it isn't just the tube - it's the whole thing. Eden WT integrated heads, The Eden Navigator, BBE BMaxT preamp, the Alembix F1x and F2B, the Demeter 201 - all tube based pre's that just a wonderful audio quality to them - to my ear none of them sound particularly good if overdriven though.
The old ART Tube Channel is a real bargain at $125 to $150 used if you can find one ... amazingly good sounding pre. Rear panel i/o and a busy front panel are the down sides. Once you suss it though - it sounds great and is way flexible.
There are a number of Solid State - no tube at all amp designs out there that do just fine at getting a warm, slightly compressed thing going on without any tube. They're generally smaller, lighter and frankly - off the shelf, easily replaced if necessary. A decent SS bass head is pretty easy to live with ... I have no problem getting my GK to that warm and full but clean and punchy place I love.
So to net some of that crap out ... for guitar, a Princeton Reverb or decent SF Deluxe is pretty tough to beat tonally. I put up with tube amp maintenance and fragility for that tone. There isn't an analog I find attractive in the bass amp world. I would like to check the Peavey VB2 out but for me, 225 watts isn't a great deal of power - and it is at least *9x the size of my 2 lb EA micro head - it's going to do something spectacular tonally to get my attention ...
* I'm guessing at 3x the height, 3x the width at a minimum ... 40 lbs + vs 2 lb ...
4mal is offline   Reply With Quote
Old February 1st, 2009, 11:54 PM   #5 (permalink)
I've a few high-power tube amps that are totally unbeatable in the tone stakes. But they're a little on the old side, and just plain ol' unreliable, not to mention almost as heavy as a late 60's VW Beetle.
If (and maybe when) I get my act together and can clone that vintage tube head with modern parts, I'll consider taking one on the road. I can upgrade it to 88s or 6550s to get the real power I want and NOT worry about it surviving a gig, and I will play it live.
I don't believe that a bassist really needs a whole lot more than 200 watts to gig. It's just like guitarists with 100watt Marshalls--if you're gigging a scene that requires a whole lot more than that, you'll probably have PA support, use it. I generally use a 200 watt 2x10 combo for rehearsal, and just augment that with a second cab on the other side of the stage at gigs.
And I really don't see much point in tube preamps mated with SS power...if you're gonna bother with tubes, go whole hog.
marshman is offline   Reply With Quote
