Old July 13th, 2008, 04:34 PM   #1 (permalink)
Steve G's Avatar
Dimensions for single 12" bass cab?
I have a 12" bass speaker which I built a terrible cabinet for last year. Really sounded bad.
So I have some wood flying around, anyone got any suggestions on what size to make a cabinet, need it to be compact as possible.
Cheers
Steve
"He was a drinkin' man with a guitar problem..."
http://www.myspace.com/stevegiddings
http://www.myspace.com/hiandlonesome
Steve G is offline   Reply With Quote
Old July 13th, 2008, 09:50 PM   #2 (permalink)
Moderator
Tim Armstrong's Avatar
Avatar makes one, here's their page for it, there are dimensions in the text:
http://www.avatarspeakers.com/sB112.htm
Cheers, Tim
http://www.moodswingers.org
Old July 14th, 2008, 05:27 AM   #3 (permalink)
Steve G's Avatar
Thanks Tim, that one looks good. I wonder if reducing its size on the long edge would lose a lot of tone? Basically, the smaller the better as Im pushed for space at home. Maybe Im trying to have my cake and eat it..
Old July 14th, 2008, 07:28 AM   #4 (permalink)
martini's Avatar
I'm using a GK MBS3 for my smaller gigs, the whole combo is barely big enough to contain the single 12 inch speaker...it sound amazing.
It shows that if the design is right, theres no need to worry.
http://www.gallien-krueger.com/produ..._co_150s.html#
Your attitude will always affect your altitude.
martini is offline   Reply With Quote
Old July 14th, 2008, 11:27 AM   #5 (permalink)
see if you can find some prints at electro-voice. they used to publish nice thiele box designs and basic pointers about box / porting characteristics especially relating to their force series instrument speaks.
I think that's actually a section of the P.A. Bible which was a free publication they started in the late seventies.
hockey_head is offline   Reply With Quote
Old July 14th, 2008, 11:34 AM   #6 (permalink)
Vince a's Avatar
It's not as simple as building a box around a speaker . . . each speaker has certain information . . . Q's, free air space, etc., etc., etc. . . . that must be used to execute the building of the box that will hold it.
Your first attempt may have not sounded well because of the size of the box - not how well you did or did not build it!
Epiphone Elitist Les Paul
Fender Am/Se Stratocaster
Fender Am/Se Telecaster
Fender '76 Doublebound Custom Telecaster
Fender Am/Se Jazz Bass and P-Bass Special
Simon and Patrick Rosewood C/W Acoustic/Electric
Vince a is offline   Reply With Quote
Old July 14th, 2008, 02:01 PM   #7 (permalink)
martini's Avatar
Very true, I attempted to upgrade my Ampeg 410 cab with much higher powered speakers.....they couldn't handle the cab. Squeaked and complained on every note below Low A.
Spoke to one the Ampeg tech guys and he told me that each of the Ampeg cabs and speaker configurations were made and tuned to each other, hence a 100 watt speaker totally outperforming a 400 watt speaker. (Made by the same company BTW.)
Old July 14th, 2008, 02:15 PM   #8 (permalink)
Steve G's Avatar
This is exactly what I feared!
Old July 14th, 2008, 09:42 PM   #9 (permalink)
4mal's Avatar
so Steve, do you have any idea of make and model of the speaker ? If not it's a shot in the dark ...
4mal is offline   Reply With Quote
Old July 14th, 2008, 10:10 PM   #10 (permalink)
Vince a's Avatar
Check this out:
Cursor down to where it starts with "Driver Properties," then look at the next three boxes to get an idea of the info that you'll need to make that box . . .
http://www.ht-audio.com/pages/BassBoxPro.html
. . . then further down it actually gets into making the right size box.
-V
PS. These are speaker boxes for cars . . .
Old July 14th, 2008, 11:01 PM   #11 (permalink)
aunchaki's Avatar
WinISD is a Windows program that help calculate optimal bass cab dimensions based on cab type, driver size, number, freq range, etc... It's cool.
Two Teles, One Strat, Two Acoustics (6 & 12 strings), One Solidbody Acoustic,
Two Mandolins (4 & 8 strings), One Bass (5 strings)
Old July 16th, 2008, 05:50 AM   #12 (permalink)
Steve G's Avatar
Nothing special, think its an eminence beta 12. 250w.
Old July 16th, 2008, 05:51 AM   #13 (permalink)
Steve G's Avatar
Check this out:
thanks,
Ill take a look..
Old July 16th, 2008, 02:09 PM   #14 (permalink)
4mal's Avatar
Eminence Beta 12A Cab designs
The link above is what Eminence recommends for a standard Beta 12. There are a coupl of fidderent Beta 12 models so you might wantto email Eminence aboutthe specific model #, that is usually on a while paper lable, stuck to the side of the magnet.
Hope that helps.
Old July 16th, 2008, 02:54 PM   #15 (permalink)
Steve G's Avatar
Thanks 4mal, thats great. Ive got some sums to do I think!
Old July 17th, 2008, 12:12 PM   #16 (permalink)
4mal's Avatar
Unless you are building hi performance sub's, tolerances of about 10% are about as good as you really need. In the land of hi performance sub's the tolerance is more like 1 % as the energy levels involved can rip drivers to shreds ...
2. See if you can find a set of the EV TL606 plans for their 3.2 cu ft bass box. Dimensionally it's all wrong for you but - it's a really good guide for how to construct a slot port bass box.
3. the area of a circle is pi*r^2 so that 3" round port translates to something like 7.07 square inches, time 2 ports is 14.1 sq in or 45.5 sq cm ... you should probably migrate from the 2 3" round ports to a shelf port design like the TL box.
4. when construcing - the shelf of the port becomes an internal brace. Make the shelf itself in 2 pieces. The front portion you make 'shallow' and fixed in place. The last piece you make removable so you can 'tune' the cab by ear at the end of the process. The bottom of the cab is also 'removable during the tuning process - glue it and screw it down after tuning. Every other joint is glued and screwed during construction.
Back to the shelf .. given that Eminence is calling for 4.154 inches in depth, or 10.55 cm, then make the front portion say 8 cm and the back portion is the remained. Make is say 6 cm. Assemble, test at low volume, disassemble, pull the back portion of the shelf, make it narrower, reassemble, rtest, listen repoeat until you get the cab tuned *right*. You can always go back to the original 6 cm depth with a new piece if that's what sounded best.
These TL parameters - the spec's from Eminence have pretty large real world fluctuations from what I'm told. The age of the driver (hours in use), the attention to detail during manufacturing that day, the humidity present during testing as opposed to when you're playing all contribute to that +/- 10% tolerance I mentioned earlier. Bottom line is that you treat these as a good place to start. Real good ideas in fact, but do not slave to that sheet in a sense af attempting to achieve 100% accuracy. There's wiggle room there ...
I'm a novice at this stuff by the way. I have built several boxes over the last coule of years but I have something of a tutor. A fellow bassist who lives nearby and has a pro sound pedigree. The construction ideas above are pretty much straight from his advice to me and now on to you... He builds some really cool stuff ...
(note: math adjusted for formula error)
Old July 23rd, 2008, 07:47 PM   #17 (permalink)
the area of a circle is pi R squared.
pi x d = circumfrance
Old July 24th, 2008, 11:48 AM   #18 (permalink)
4mal's Avatar
Thanks for the heads up. You would think that by 3PM I'd be awake enough ... but no....
