Crack Problem, What to do?
I bought this 2000 Fender body cheap ($20) and it had the pickups and hardware too. It's a jazz bass, but I don't know what quality, it's stamped with a date on May, 28 2000 stamped in black and Mar 2000 X40860 in bigger letters in red.
The guy said that the guitar was in a car accident (never let them drive after a gig). There's a nice sized crack that can be seen on the front and back of the guitar that starts in the pocket and moves down the back. The pocket itself looks solid. Take a look at the photos and let me know if you think it's salvageable? I'd love to use it for my first bass build.
“You don't find a style, ... a style finds you.” Keith Richards |
| Sponsored Links |
That looks like a pretty severe structural crack to me but I'm no authority.
Can you open it up any by flexing the body gently? I did this on a crack in the neck pocket of my 66 Tele that I restoring. After opening it a little I used a syringe to inject some heated gorilla glue in the joint. It didn't look as bad as this. |
Do what you have to do to squeeze the crack as tight as possible, so that the cracked edges meet and there is no air gap. Wick in quality water thin CYA (Hot Stuff, Zap, Jet, etc) to wherever you see the crack's hairline. Do not gush in the CYA - apply sparingly. As the CYA is sucked into the crack, reapply 'til it will no longer wick in. The cracked area will more than likely be stronger than the wood itself.
Rob,
I'm new to this, but excited to try. What does that mean; "wick in?" My guess is that you apply the glue into the crack by just letting gravity let it run down into the crack until it won't take any more. Is that right? I'll clamp it after gluing to assure a tight fit. Thanks again
#7 (permalink) | |
Car accident ? Terrible when people funk n drive at the same time.
Seriously : IMHO try to not widen the crack. Once wood deforms it never goes back the way it was. It's hard to see from the photo but could you drill a 1/16" dia. hole, at an angle down-wards into the crack, from the neck bolting hole or another area that would be concealed when the bass is re-assembled ? That would give deep access to inject this low viscosity glue. http://www.leevalley.com/wood/page.a...at=1,110,42966 |
OK, I understand what to do and have ordered the glue.
Thanks very much, hopefully I'll get my crack problem under control.
#13 (permalink) | |
http://www.stewmac.com/shop/Glues,_a.../Pipettes.html They have a needle like tip on them that fit easily in a 1/16" hole. I drilled a few shallow holes (about 3/8" to 1/2" deep) in the neck pocket trying to follow the angle of the crack and injected glue in these using the pipette. Worked well with the watery glue. Good Luck doster. |
#14 (permalink) |
Using the supplied "needle" tip that comes with the typical CYA plastic bottle is all ya need - if the crack joint is tight, just touching the tip to the crack and slightly squeezing the CYA bottle will have the crack sucking in any pooled glue. Any CYA residue can be picked up by just touching it with a small piece of paper towel - watch how quickly the CYA wicks in!
#15 (permalink) | |
My bottle is capped with a closed lid as the original needle tip clogged months ago. |
#16 (permalink) |
Today the glue was delivered and I went out a bought a big clamp to force the crack together, Some areas of the crack, especially near the pocket wicked in lots of glue. Other parts wouldn't take much. I'll have the clamp on until tomorrow and then will take a look.
#18 (permalink) |
It looks good, I've been on evilbay buying parts to put it together. I got a USA neck for $167, which I think is a good deal. Got all the other assorted parts pretty cheap too.
My theory is to put it together before I refinish the body, just to make sure that the crack isn't a problem. Then play it for a while and see how it sounds. I've got a good feeling because the crack wicked in all that glue. After that I'll take it apart, strip what's left of the finish on the body and re-paint. The other way to do it would be refinish the body then put it back together, that way it would be done, but I think it makes sense to see how the crack holds up under the tension of the strings. I've got everything but the neck, once it comes I'll put it together and report back.
#19 (permalink) | |
#20 (permalink) |
I've started to assemble the parts and I've got a wiring question. I'm looking at the Fender wiring diagram for an American Standard Jazz Bass and there's no wire coming from the inner ring of the output jack, is that correct? Just one from the outer ring to center lug of the tone pot?
Still need to replace the pots and then I'll put it all together, it's going to look pretty ugly at first, but hopefully there will be no crack problem and I can get to work on the re-finish.
#22 (permalink) |
That's what I thought.
This is the link for what I'm using. http://www.fender.com/support/diagra...660_62APg2.pdf I hope to wire it up this weekend. So I can play around with it.
#24 (permalink) | |
Since all mount thru the metal plate they all are sharing the ground and that's why there's no ground wire to the jack on the Fender diagram.
No ma'am I'm not Elvis, I'm just the bass player. |
#25 (permalink) |
Wired it up and everything seems fine except I broke the resistor (I think that's what it's called) taking it off the old tone pot. If I take it to Radio Shack should they be able to figure out what I need? Says .05 on the wiring diagram.
I left the inner connector unwired and everything seems to be fine, just your normal 60 cycle hum.
“You don't find a style, ... a style finds you.” Keith Richards Last edited by doster; July 12th, 2008 at 07:24 PM. Reason: Adding jack wiring info |
#26 (permalink) | |
