Old June 4th, 2008, 05:22 PM   #1 (permalink)
bronco bass to mustang bass???
i was looking on musicansfriend to day for a cheap bass cause i want to start learning bass.it is possible to convert a bronco bass to a mustang bass or are their body styles different?
nicktele5150 is offline   Reply With Quote
Old June 4th, 2008, 09:06 PM   #2 (permalink)
Shoved BassVIII's Avatar
Wasn't Tim Armstrong doing that exact thing not too long ago?
Shoved BassVIII is offline   Reply With Quote
Old June 4th, 2008, 11:58 PM   #3 (permalink)
rahbee's Avatar
I was just thinking of doing something similar to my bronco. guitarpartsresource has the mustang pickups.
http://www.guitarpartsresource.com/b...ndemustang.htm
____________________________
"I've got a beat up Silvertone amp
I plug it in and it sounds like a champ"
rahbee is offline   Reply With Quote
Old June 5th, 2008, 02:13 AM   #4 (permalink)
Moderator
Tim Armstrong's Avatar
Yep. The bodies are identical, except for the pickup rout, and the pickguard does a nice job of hiding excessive routing! Here's a Musicmaster body that's about to become a Mustang body:
Cheers, Tim
http://www.moodswingers.org
Old June 5th, 2008, 02:39 PM   #5 (permalink)
thanks tim.
Old June 5th, 2008, 02:51 PM   #6 (permalink)
rahbee's Avatar
Cheers, Tim
is there a thread on that bass? what color is it going to be?
Old June 5th, 2008, 06:03 PM   #7 (permalink)
Moderator
I've posted that picture recently, probably in another thread. I don't recall if I had a thread on it, though. It's a 1973 Musicmaster Bass body, and I have a 1973 Musicmaster Bass neck for it (I actually have two of them, one is on Pinky, the bass I usually gig).
It's going to be black (always did like black with MOTS pickguards!).
Cheers, Tim
Old September 29th, 2008, 08:52 AM   #8 (permalink)
Deacon Blues's Avatar
Tim did you ever finish that bass?
Tim,
I was just wondering if you ever finished your Mustang/Music Master bass project. If so, do you have any pictures of the finished guitar?
This is the age of the expanding man.
Deacon Blues is offline   Reply With Quote
Old September 29th, 2008, 10:27 AM   #9 (permalink)
Moderator
Originally Posted by Deacon Blues View Post
Tim,
Not yet! I got sidetracked by a few other projects. I think this will be something to do now that the tourist season is over and I'll have more evenings at home...
Cheers, Tim
Old September 29th, 2008, 11:22 AM   #10 (permalink)
Good luck ever finding a genuine Mustang bass bridge. Unique to that model and it seems absolutely no one sells an aftermarket. Maybe someone in Japan? I don't check the bay for 'em but don't imagine they come up often and are probably spendy when they do.
EddieN is offline   Reply With Quote
Old September 29th, 2008, 11:36 AM   #11 (permalink)
Moderator
I'm going with a regular P-Bass style bridge, since the body isn't drilled for string-through anyway.
Cheers, Tim
Old September 29th, 2008, 04:24 PM   #12 (permalink)
Yeah, I figured you knew about the bridge, Tim. It was just a FYI for the others who've had this thought. I've had it too.
Old September 30th, 2008, 01:22 PM   #13 (permalink)
Dennis_UK's Avatar
Basspartsresource.com have 4-saddle Musicmaster bridges in stock - looks the part more than the standard P-bass bridge does...
Fender MIM Precision, all black, 2004.
Fender MIJ Precision, '51 RI, Butterscotch, 1996.
Squier VM Precision TB, 3TS, 2007
Markbass CMD121H 1x12 combo plus 1x12 ext cab
My band: The Rock'nRoll Outlaws
Last edited by Dennis_UK; September 30th, 2008 at 01:23 PM. Reason: typos...duh...
Dennis_UK is offline   Reply With Quote
Old September 30th, 2008, 04:47 PM   #14 (permalink)
Basspartsresource.com's Musicmaster bridge is a Fender replacement part and is intended for use on a string-through body. I've used one after modifying it for top-loading. The mod is a bit crude but functionally it is fine.
ponticat is offline   Reply With Quote
