Old December 7th, 2003, 02:56 PM   #1 (permalink)
Make your own pickguard.
My Tele is a mutt. The thing has been routed four times so the knob cavity is about 50% longer than the original space. However, I was able to cover it with a Tele guitar plate. Except for the switch slot which taunts me it's worked out ok.
I figured I'd make my own pickguard since the pickups for this bass are near the bridge and not in the neck position. Using the 51 reissue pickguard I could start with that and improvise a little. However, when I went to Home Depot to find a sheet of plastic nobody knew what I was talking about. First I was sent to where they have plastic sheets, drop cloths for painting. Then I was sent to where they have Lucite hard plastic sheets for replacing broken windows.
What I want is a colored plastic, preferably white, that is about the same width as a regular pickguard. What should I ask for since my attempts so far have proven futile?
Harvey is offline   Reply With Quote
Old December 7th, 2003, 03:07 PM   #2 (permalink)
fenderslaper's Avatar
You could try...
Ordering a blank from one of the pickguard mfg. Co's like WD, or Jeannie.
'slaper.
fenderslaper is offline   Reply With Quote
Old December 7th, 2003, 07:20 PM   #3 (permalink)
Moderator
Tim Armstrong's Avatar
Stew-Mac
Stewart-MacDonald http://www.stewmac.com sells just about any pickguard material you could ever want...
Cheers, Tim
Old December 8th, 2003, 03:35 PM   #4 (permalink)
Stew Mac is the place to go for the do-it-yourselfer, but WDmusicproducts.com will cut you one from a traced pattern.
brock29609 is offline   Reply With Quote
