Treat everyone with respect, no matter how difficult that may be.
Old March 13th, 2008, 02:01 PM   #1 (permalink)
telecaster bass build questions
hey everyone, i saw a picture on here a while back where a poster made a bass using a telecaster guitar body, and im thinking about trying to build one this summer. Im new to building guitars, so any advice is welcome. Also, will i have any problems if i just throw a bass neck and bridge on the guitar body and use the tele pickups?
spook-e is offline   Reply With Quote
Old March 13th, 2008, 02:18 PM   #2 (permalink)
search, Tim Armstrong has a friend who builds what you describe. The basics of the project are well documented. BE AWARE THAT THIS IS A SHORT SCALE BASS. The project Mr. Armstrong described used a Bronco neck and a Squire tele body. Pickups are not a problem: scale could be. I was young once, so I'm told, however I have aged and think perhaps you should just buy a fender bass and be happy. bil
bilpfeiffer is offline   Reply With Quote
Old March 13th, 2008, 08:07 PM   #3 (permalink)
rhomco's Avatar
Here is an option
This uses a standard tele body with the neck slot deepened to the rear of the neck pickup cutout and widened just a frog hair on both sides. I used a Fender Bronco Short Scale neck and re-cut the headstock to a teleish shape. The standard tele bridge pickup location is just right for the bronco bass location. My bass player simply raves about this bass. I have to bring the damn thing to every jam/gig. I dont think you could get by with a full 34 inch fender bass neck due to the length needed not to mention the severe neck dive you would get. Trust me, this little guy holds it's own against any rock bass.
Good Luck with whatever you choose,
Rob
If I won the Lotto.... I'd just build (OK, OK Assemble) guitars and sell them till the money ran out
rhomco is online now   Reply With Quote
Old March 13th, 2008, 10:15 PM   #4 (permalink)
Moderator
Tim Armstrong's Avatar
rhomco, you absolutely ROCK! Really, everything you've posted has cause me serious drool problems...
bilpfeiffer, it was one of the other Tims, not me, that posted about the Tele-bodied bass. I AM a Fender short-scale kinda guy, and was seriously looking to do that kind of thing, but I found a Musicmaster Bass body for cheap and went that way instead.
Cheers, Tim
http://www.moodswingers.org
Old March 14th, 2008, 08:11 AM   #5 (permalink)
rhomco's Avatar
I'm thinkin it was 3 fingers Tim
Cheers, Tim
He is the guy that started this whole idea here. I just "amplified" it.
Rob
Old March 14th, 2008, 01:42 PM   #6 (permalink)
broadcaster's Avatar
Nice bass, rhomco.
A bass playing buddy of mine has a hollow body Tele bass with an F hole. I played it and it is sweet. He said he ordered it new from Fender Japan.
groovalicious
broadcaster is offline   Reply With Quote
Old March 15th, 2008, 05:50 PM   #7 (permalink)
The first time I saw Rhomco's Tele-Bronco hybrid I knew I had to build a similar bass; thanks for the inspiration! My version is as follows: Homemade Tele body (clear lacquered African mahogany), back routed cavities for Duncan Quarter Pound single coil pick up and controls (in the doubtful case I ever want to add controls), Stew Mac side mount jack and a thumbrest made from body blank waste. Bronco headstock reshaped into Tele-esque form. Other parts from the Bronco donor: Bridge and saddles, tuners, string retainer and strap buttons. Strung with LaBella flatwounds. Vinyl decal logo.
ponticat is offline   Reply With Quote
Old August 17th, 2008, 11:53 AM   #8 (permalink)
Bluesbob's Avatar
I think I actually need something like this.
What, me worry?
Bluesbob is offline   Reply With Quote
Old August 20th, 2008, 03:59 PM   #9 (permalink)
tom grossheider's Avatar
Sweet looking projects! Bet they sound every bit as good as they look. Crazy!
tom grossheider is offline   Reply With Quote
Old August 22nd, 2008, 12:11 PM   #10 (permalink)
Muddslide's Avatar
Rob
Lordy, that is absolutely SMOKING HOT!!!!
Pure class. You do good work, my man.
Muddslide is offline   Reply With Quote
Old August 22nd, 2008, 12:13 PM   #11 (permalink)
Muddslide's Avatar
Also a beauty! Wow.
Can I ask where you got the vinyl headstock decal? That's cool!
Old August 22nd, 2008, 05:30 PM   #12 (permalink)
My own design, done in CorelDraw and printed by a local franchise sign shop using a Gerber "Edge" machine (10 copies for $36.00).
Old October 1st, 2008, 11:07 PM   #13 (permalink)
Or you could order the tele body from warmoth. Its a bit bigger so you can use a longscale neck.
stratomaster is offline   Reply With Quote
