Old September 9th, 2007, 07:40 PM   #1 (permalink)
MulliganChebichev's Avatar
Strap locks on a new strap
The little hole on the strap is about half of the (Schaller) strap lock.
What do you guys do?
MulliganChebichev is offline   Reply With Quote
Old September 9th, 2007, 09:05 PM   #2 (permalink)
boneyguy's Avatar
I've always just taken an exacto knife or razor blade and cut four little slits opposite eachother. Then lift each of those four little tabs of leather you've created and trim them back a little. Even if you go a little too deep with the slits the device locks onto the strap firmly enough that I've never had any problem.
It's been a while since I've used the Schaller ones. I switched over to the Dunlop style but my method should work with both.
I've ordered a set of these to try. They look kinda cool.
http://http://grotro.com/NuartiststrapMain.html
"Science doesn't prove, it probes."
Gregory Bateson
boneyguy is offline   Reply With Quote
Old September 9th, 2007, 09:54 PM   #3 (permalink)
SixStringSlinger's Avatar
If you can live with the plain-ness, Dunlop Cliplok straps are great. They're really comfy, that the end bits stay attatched to the guitar. You clip and unclip the strap with buckles like you see on bookbags. I've had one for a few years now. It still looks good, is as comfortable as ever, and has never come unattatched unless I've purposely unclipped it or unscrewed the end bits off the guitar.
"Is a hippopotamus a hippopotamus, or just a really cool opotamus?"
-Mitch Hedberg
SixStringSlinger is offline   Reply With Quote
Old September 9th, 2007, 11:30 PM   #4 (permalink)
modelo dos's Avatar
If you have a hammer, a vise (mainly the anvil part) or a piece of plate metal and a small piece of metal tube (threaded nipples for lamps work pretty well)...just lay the strap end on the anvil (finished face up), align the tube with the current hole and give her a good whack...not exactly professional leather crafting, but it does work and makes a nice clean (and enlarged) hole...
Just did this to a tweed strap with leather ends I picked up for my Tele. All that said, those Dunlop straps mentioned above are nice and work well in lieu of strap locks. I have a pre-Dunlop clip-lock strap as well, the only down side is the tails left on your git might keep it from fitting in your case (depending on case style).
Regards,
Dave
modelo dos is offline   Reply With Quote
Old September 9th, 2007, 11:51 PM   #5 (permalink)
Home Grown Tele's Avatar
Buy yourself a tapered reamer. That's what I use on mine. You can get a cheap one from here:
http://www.hobbytool.com/index.asp?P...PROD&ProdID=28
Plus it can be used to ream out pegheads for a good tuner fit!
Home Grown's MySpace Page
Chris Leger- "I freeze all the electronic parts of my guitars. It gives them a piquant, morsellated quality, with none of the unctuousness of more garrigue components."
Home Grown Tele is offline   Reply With Quote
Old September 10th, 2007, 12:36 AM   #6 (permalink)
studio1087's Avatar
That's exactly what I do but I use a really good steak knife. I'll bet that I have 15 straps with Schaller Strap Locks. I have straps that are 20 years old and the Schallers work great.
John
Old September 10th, 2007, 06:53 AM   #7 (permalink)
cRaZY Tom's Avatar
yeah i live by Schaller straplocks, i've had mine for years and they have never failed me, I also use the craft knife method!
cRaZY Tom is offline   Reply With Quote
Old September 11th, 2007, 11:05 PM   #8 (permalink)
I use Grolsch.
http://corporatetshirt.com
jonzer is offline   Reply With Quote
