Old January 13th, 2007, 06:11 AM   #1 (permalink)
Ivan's Avatar
Guitar cable - shielded end question
after many many years of playing through free cables, i decided it was time to invest in a quality one.
I just bought a Planet Waves one, and while reading the box i notice one end of it is a shielded end. I was wondering what this actually means - why just one end? is the shielded end meant to go in the instrument?
Ivan
__________________________
'06 Gibson Les Paul Standard
'06 Martin D-35
'06 Fender AV '62 Stratocaster (Wildwood Thinskin)
'05 Fender AV '52 Telecaster
Ivan is offline   Reply With Quote
Old January 13th, 2007, 06:17 AM   #2 (permalink)
playanotherchord's Avatar
the shielded end needs to go into the amp, or effects, or whatever's on the other end. Its supposed to protect your guitar from electric surges. I've used Planet Waves cables extensively, and one thing you should note is that the compression spring thingys they have will widen the jack on your guitar, so it will become difficult to use cables without the compression springs. Not a bad thing per se, just that you may end up having to stick to Planet Waves cables if it gets really bad. My brother's bass had that problem, but it was a cheap bass, so I can't really say if it was more the cable or the quality of the jack.
playanotherchord is offline   Reply With Quote
Old January 13th, 2007, 06:32 PM   #3 (permalink)
woodman's Avatar
i use Planet Waves cables exclusively now, they're great gear for my money. you can color-code your shielded end with the little colored rubber-band thingies that come with the package, so you know which end goes where at a glance. why only one end? here's what Planet Waves sez:::
This configuration provides the best shielding against external noise. The shield intercepts external noise and diverts it to the amplifier ground, reducing interference. Connecting the shield to the amplifier end provides the shortest and most direct path to the amplifier ground and maximizes the shielding effectiveness. If the shield is connected at the guitar end, the intercepted noise is forced to travel through the cable before reaching the amplifier ground; this causes extra noise pickup by the cable and reduces shielding effectiveness. If the shield is connected at both ends, some of the noise can still travel through the cable before reaching the amplifier ground, thereby reducing shielding effectiveness.
the jacks i've had in my guitars can be bent to tighten back up if they get slack.
BAND PAGES:
Old January 13th, 2007, 07:15 PM   #4 (permalink)
Ben Harmless's Avatar
Sooooo... the guitar is not grounded anymore?
No thanks, I'd rather maintain a safe amp and keep grounding the noise that's produced within the guitar.
"The intercepted noise is forced to travel through the cable..." So when you don't clip the shield on one end, it magically gets grounded without travelling through the cable?
A little snake oil there methinks. Not on the level of Monster Cable, as this is a genuine difference that does offer some utility in limited circumstances, but I doubt it'll really make for better tone in the end.
- B. Simpson
Old January 13th, 2007, 07:27 PM   #5 (permalink)
R.I.P.
Pete Galati's Avatar
This isn't something I've looked into, but it seems like the guitar's negative still has to be connected to the amp, or you won't hear anything. So they must have two conductors inside the shield, but the shield is only conected at the amp end. I can't think of any other way to make that work.
Pete
Old January 13th, 2007, 07:35 PM   #6 (permalink)
woodman's Avatar
Originally Posted by Pete Galati
they must have two conductors inside the shield, but the shield is only conected at the amp end. Pete
that's the way i understand it. i found all that info after i'd already bought a couple -- mainly for rugged construction and low capacitance.
BAND PAGES:
Old January 13th, 2007, 07:38 PM   #7 (permalink)
teleclarkster's Avatar
This is nothing new. In audio systems, especially on balanced cables I float the shield or "drain" wire on outputs of devices and tie it on the input of another device. This will prevent ground loops between equipment. Then any RF or other noises that get on the shield are drained through the ground of the gear that it's tied too. You can do the same thing with a guitar cable if it has 2 conductors and a shield. I've made plenty and they work well.
teleclarkster is offline   Reply With Quote
Old January 14th, 2007, 02:33 AM   #8 (permalink)
Rick S's Avatar
That's correct. They are basically a conventional cable with a braided shield but it has an additional foil shield over that. They are still slim and very flexible, really no negatives and the secondary shield can be effective against some RF problems, but to the most part you will never notice any difference. So, don't worry if you plug it in backwards.
I'm with Woodman, I've used these exclusively for several years and haven't had a failure. Rugged rascals.
Rick S is offline   Reply With Quote
