Old January 3rd, 2007, 08:29 AM   #1 (permalink)
Caper's Avatar
Computer help: Upgrading USB Card 1.1 to 2.0
I'm looking at upgrading my USB card, I've added a 200Gb external harddrive so it's time to upgrade the card. I'm trying to buy a card off the net since Staples and Radio Shack want about $60 Cdn for a new card. My computer is about 6 years old, Pentium 1.6. I'm also looking to add an additional port at the front of the tower for easier access. I would appreciate if someone could tell me what would be compatible with my machine, thanks.
Caper is offline   Reply With Quote
Old January 3rd, 2007, 10:27 AM   #2 (permalink)
Administrator
I'd get a new computer if I were you. You're just adding bandages to a 6 year old computer. I did that once with an old PC that I was trying to get up to speed for recording. In the end I had an old computer that didn't work so well that cost more than a brand new "cheap' computer.
In general, any PCI based USB 2.0 card would work. But, because of your desire to add a port at the front of the computer I have no idea what could be compatible with "your machine."
Good Luck with that.
Here's a link to a CompUSA 6 port PCI USB card for $14. Two of the ports are internal so maybe they could be used to add some front ports. Don't forget to completely remove any existing USB driver, ports etc that you have:
http://www.compusa.com/products/prod...a=&cm_ite=feed
TDPRI is offline   Reply With Quote
Old January 3rd, 2007, 11:19 AM   #3 (permalink)
Spenceh's Avatar
Hi Caper, using USB 2.0 is fairly dependant on the OS you are using - we had some Win 98 machines that just did not work and others that were not easy to use.
This site may help http://www.everythingusb.com/usb2/faq.htm
Hope this helps
Spenceh is offline   Reply With Quote
Old January 3rd, 2007, 02:36 PM   #4 (permalink)
Caper's Avatar
Thanks for the info, btw I'm running XP and I could probably do without the hubs in the front I guess.
Old January 3rd, 2007, 03:07 PM   #5 (permalink)
Mark Davis's Avatar
You can get a whole new motherboard for $59 that has 2 USB ports on front and 4 on back. Thats what I would do if its not too much trrouble for you to do the swap.
Old January 3rd, 2007, 03:24 PM   #6 (permalink)
Gary Lee's Avatar
Caper, not knowing what brand of computer you have is strike one, I'm no computer geek, so that is strike 2. Strike 3 is if I even knew what brand your computer is, it wouldn't help. The good news is I upgraded my 5 year old Dell to a 2.0 USB port and it was just as easy as dealing with a third lead player in a band that couldn't or wouldn't shut up. Yep, he should have known some steel players carry extra wattage. Hope that never happens again....
The only precaution I recall is to avoid static electricity. Switch out the cards on a work bench that is located in a room that isn't carpeted. Then you have to do something to discharge static that may be on your body, like eat some raw broccoli and wash it down with a pint of chocolate milk...
Gary Lee is offline   Reply With Quote
Old January 3rd, 2007, 04:01 PM   #7 (permalink)
Caper's Avatar
Ok, right now I have an AOpen AX4BS P4 Socket 478 4X AGP ATX Motherboard, PC-133 SDRAM and Ultra DMA-33/66/100Bus Master Ide. 512MB Ram, 40G internal HD and 200G external HD. So I'm guessing if I do the motherboard swap, I'm looking at a ram upgrade as well? I have 512MB PC3200 Ram if that helps and a Celeron D 2.66GHZ/256/533/04A CPU and fan. I forgot about these parts. I had another computer fixed under warranty and these parts were given back to me. Would this work for my tower? Do I have to buy a board with the same socket number?
