Old January 2nd, 2007, 11:22 PM   #1 (permalink)
Stuffed Danno ?
My daughter's boyfriend received an old Danelectro from his uncle, which needed a new jack & plate installed.
When I removed the access cover on the back, I discovered the whole body of the guitar was stuffed with napkins!
Now, since this is the first Danno I've ever worked on, I'm wondering if there's some logical explanation for this.
I'm pretty sure they're after market napkins, not factory ones, since they have a print of some sort. And the first one I pulled out appeared to have barbeque residue on it.
I stuck it back inside and plan to act like I didn't notice anything odd.
But since I did, I'm wondering if anyone else out there has encountered this phenomenon.
What I mean is, sometimes I just don't know what I mean. Ya know what I mean?
PapaBeef is offline   Reply With Quote
Old January 2nd, 2007, 11:31 PM   #2 (permalink)
Probably an attempt to counteract feedback.
It's a chromyte (balsa wood) center block! HAHAHA
Old January 3rd, 2007, 01:18 AM   #3 (permalink)
Cyrithicus's Avatar
Yup, I heard of 335's getting stuffed with cottonballs for the same reason.
"When I was young, I could remember anything, whether it happened or not." --Mark Twain
Cyrithicus is offline   Reply With Quote
Old January 3rd, 2007, 01:32 AM   #4 (permalink)
aznrambo481's Avatar
"after-market napkins"?
Check out my bands, and feel free to PM me comments on them!
The Eclectics (guitar/vocals)
SLIP (bass)
aznrambo481 is offline   Reply With Quote
Old January 3rd, 2007, 01:39 AM   #5 (permalink)
E.D. Patton's Avatar
I've encountered this before.
I just keep a box of Wet Ones on my amp so I can clean up after eating BBQ on the gig.
Never thought to try napkins in the control cavity, though.
E.D. Patton is offline   Reply With Quote
Old January 3rd, 2007, 06:23 AM   #6 (permalink)
RomanS's Avatar
Maybe Glendale should get into this business - and sell them for 20 bucks a piece...
Old January 3rd, 2007, 06:30 AM   #7 (permalink)
Yeah, I once spent two hours with a long pair of tweezers pulling packing peanuts out of a Gibson Johnny Smith. It wasn't fun.
.... Hail, Hail, the Workin' man. I work hard every day.....
Ed Miller is offline   Reply With Quote
Old January 3rd, 2007, 06:35 AM   #8 (permalink)
PraiseCaster's Avatar
I've heard of some stuffing rags into 335's and 330's, though I myself have never seen it. The only thing I could think of was, that maybe it lessens vibrations along the top and back archtops, bnut I dont think it would act like a block of wood behind the pups?
PraiseCaster is offline   Reply With Quote
Old January 3rd, 2007, 08:12 AM   #9 (permalink)
Disastercaster's Avatar
Sounds like a perfectly logical place to keep napkins to me.
Disastercaster is offline   Reply With Quote
Old January 3rd, 2007, 08:30 AM   #10 (permalink)
markothefish's Avatar
some people used to stuff Styrofoam pieces into Epiphone Casinos , to cut down on feedback because they are hollow. But Old dirty napkins thats new to me ...
Quote me as saying I was mis-quoted.
Groucho Marx
markothefish is offline   Reply With Quote
Old January 3rd, 2007, 10:14 AM   #11 (permalink)
I guess it could be an attempt to control feedback. I didn't think of it as a hollow body because it doesn't have holes. But it's the cheesiest guitar I've ever had apart, including a few 1960's imports...Aside from the Masonite top & back over a plywood frame & balsa block with the plastic binding tape,
1 screw holds the bridge plate to the guitar. And the strings fit into slots at the bottom of the plate, putting all the tension on that single screw.
3 neck bolts, running in a straight line down the center of the neck, which doesn't really fit into a pocket like most guitars. And it seems to me like the bolts could actually cause the neck to split. ..Worst damn tuners ever. And it has an aluminum nut that's never been trimmed down & holds the strings about 1/4" at the first fret. The intonation is a beast, too. That's adjusted by angling a rosewood bridge saddle that's secured to the bride plate with 1 screw in the center.
All in all, it does seem like the type of guitar that would benefit from being stuffed with old napkins.
Amazingly, it still sounds nice!
Old January 3rd, 2007, 10:25 AM   #12 (permalink)
quackerz's Avatar
I have stuffed two Danos in the past with sound-proofing material and it does eliminate feedback. Not sure if napkins would have a similar effect. These were hollow Convertible models and I had to cut a pickguard to cover the sound hole. This was necessary if you wanted to play the things at any considerable volume. They had different tuner sets and one was worse than the others - the 6 inline ones in an enclosed steel box. No hope for those. The others can be coaxed to work with silicon grease on the gears and light machine oil in the post bushings. No hope for that aluminum nut and I replace those horrible bridges with cheap Tune-O-Matic knock-offs which have a similar height and spacing to what's needed. It's all worth it for that sound though!
quackerz is offline   Reply With Quote
