Old August 7th, 2006, 07:03 AM   #1 (permalink)
Blazer's Avatar
Building a strat
Well, as you people might have read in my "fixing a headstock" topic, I am the proud owner of a late eighties Squier Stratocaster which I bought new on my fifteenth birthday back in 1991, this old girl, lovingly called "the Veteran" has been through a LOT of modifications but now I'm restoring her to strathood.
But as to take three dimensional photograph I'm building a closely matching replica of how the "Veteran" used to look with the mods and all. I'm thinking of naming that one "The rookie"
The "Veteran" before the restoration, the "Rookie" wil look just like this.
Old August 7th, 2006, 01:05 PM   #2 (permalink)
Blazer's Avatar
Here's the raw maple with the strat routing template
After sawing off the exess wood, ready for routing
After routing, a nice clean maple strat body to be.
Routing out the neck pocket, I put in the neck to check if I haven't routed it too dep, luckely, I got it right.
And so I started working on the vibrato channel
And while doing so I completely forgot that I had a camera with me and failed to document the routing of the pickup and control routs, and of me bevelling the body. I only remembered my camera when I put the thing together to see how it looked.
Artist impression of what the Rookie will look like when finished.
The "Rookie" at home.
The neck, Kahler Vibrato, pickups and pickguard all come from "the Veteran" as you can see I am FAR from finished, I need to drill the holes for the bushes of the vibrato and spray the body in sealer before I can add the first layers of red.
It'll be a long time before I can play the "Rookie" but I'm having a ball just making it.
Old August 9th, 2006, 06:07 PM   #3 (permalink)
Blazer's Avatar
The "Rookie" in its filler coat, showing how green she is right now. I put the neck and other hardware on to see formyself how she will look when done.
A close up on the Kahler bridge showing the studs I inserted today.
and so the build goes steadily forward.
Old August 10th, 2006, 03:06 AM   #4 (permalink)
Nice work Blazer. How heavy is it?
chickenpicker is offline   Reply With Quote
Old August 11th, 2006, 10:26 AM   #5 (permalink)
Blazer's Avatar
I did the last sanding job and put the body in primer. Now I need to start wet sanding (after the primer has dried of course) and then I can start applying the layers of color.
Boy I'm having fun with this.
Old August 15th, 2006, 08:57 PM   #6 (permalink)
Blazer's Avatar
Okay you guys, I finished Building the "Rookie" compare it with the Picture of the Veteran in the beginning of this thread.
As you guys can see, I went with a different neck. I could get this gorgeous Birdseye maple neck for a bargain price and I went for it. Apart from the headstock shape I suceeded in making a matching copy of the "Veteran" They look so similar that I have to catch myself sometimes. The swimmingpool rout of the Rookie gives it a very airy open sound, I figured that the all maple construction would result is a very bright sound but that's not the case, it has a very tight low end and it nails that David Gilmour tone when overdriven. All in all this project was a success.
