Old July 5th, 2012, 02:28 PM   #1 (permalink)
emu!'s Avatar
What do ya'll think of this invention idea?
With all the fires on the news, I came up with an idea that doesn't seem too far fetched. Here is is:
New houses would be build with a sprinkler system on the roof. A large water pipe, that is shut off at all times unless a fire is approaching, would be located at the very top of the houses gable (or around the edges). When the owner decides the fire is getting close, the roof-top sprinkler system would shower the house with water constantly.
Do-able?
emu! is online now   Reply With Quote
Old July 5th, 2012, 02:47 PM   #2 (permalink)
Alamo's Avatar
You had roast beef lately?
I guess the house will be well done and nice & crispy on the outside.
....and That's When the Racoon Attacked My Leg
http://www.myspace.com/timebanditsberlin
Alamo is online now   Reply With Quote
Old July 5th, 2012, 02:50 PM   #3 (permalink)
Mjark's Avatar
Does the house have gutters?
Mjark is offline   Reply With Quote
Old July 5th, 2012, 02:51 PM   #4 (permalink)
- You know , probably very do-able.,, however,
Just like airplane safety, ..they had a special on TV, that went through various
safety devices for planes including, wing-parachutes, ejector seats, etc,...all of it could save lives, but, was too expensive to make viable.....
Nice idea, ....though
A person who won't read has no advantage over one who can't read.....
Mark Twain
uriah1 is offline   Reply With Quote
Old July 5th, 2012, 03:08 PM   #5 (permalink)
Do-able?
It's been done, as it turns out. Some of the really rich people down here in San Diego live in what are, to put it mildly, high fire danger areas - and they have pretty much the exact system on their homes that you describe.
Just a fire sprinkler system put on the outside instead of on the inside.
Also have seen a 4x4 firetruck, designed to fight brush fires, that has this as well in case the vehicle is overrun by fire.
Arbiter is offline   Reply With Quote
Old July 5th, 2012, 03:10 PM   #6 (permalink)
ADinNYC's Avatar
I've often thought of the same sort of thing. There must be some sort of technology available. Maybe a giant fire resistent blanket? Fire retardent gel? I don't know....seems like there must be something.
He said to the music store clerk - "Do you have a pedal that makes it sound like I'm plugged straight into my amp?"
ADinNYC is offline   Reply With Quote
Old July 5th, 2012, 03:14 PM   #7 (permalink)
scat4me's Avatar
Just don't use PVC
scat4me
I'd play much better if I knew what I was doing!
scat4me is offline   Reply With Quote
Old July 5th, 2012, 03:15 PM   #8 (permalink)
Joe Sailor's Avatar
It depends on what you are protecting. Houses with sprinklers inside significantly increase survival rates. Some buildings do have a deluge system on the exterior, the ones I know of are airports were fueling is close to the windows to protect them from breaking and letting heat and smoke in.
What about clay tile roofs that cannot burn?
Joe Sailor is online now   Reply With Quote
Old July 5th, 2012, 03:16 PM   #9 (permalink)
Bones's Avatar
It's a good but expensive idea IF you have city water. If you are on a private well, chances are the power lines will fail in the fire and the system wont run. I guess if you have a big generator hooked up you could prevail, but all these things cost a lot of money.
Bones is online now   Reply With Quote
Old July 5th, 2012, 03:42 PM   #10 (permalink)
ADinNYC's Avatar
I guess there might be a way to stop the flames but stopping the heat is another matter.
Old July 5th, 2012, 06:08 PM   #11 (permalink)
Truck bedliner (the spray-able stuff) is bombproof, fireproof, and waterproof.
So, just coat your house in bedliner. Couldn't be simpler, right?
-kmac
Fender Mex Tele -----> Fender Mustang II
Planning double bound LPB esquire build.
kmacaster is offline   Reply With Quote
Old July 5th, 2012, 06:11 PM   #12 (permalink)
fuzzbender's Avatar
i'd move
fuzzbender is offline   Reply With Quote
