Moderator
I always wondered that too until I got the complete answer....the forward position gives a deep, pre-set bassy tone, the middle position gives the pu with the tone control, and the back position gives the signal straight through to the output by-passing any tone control. A lot of people say they can hear the difference between the back position and the middle position with the tone control wide open; they say that even with the tone wide open it sounds different than the back position; I sure can't, must be my old ears....
I can tell the difference actually, perhaps because I have an old one. I just put a Fralin into the neck slot and rewired to accepted Tele specs, but am considering changing the tone pot to a push pull affair to allow for that bridge, no tone control in the circuit setting, and in the process also gain a neck or both setting with no tone control in the circuit. I think VanHalen's frankenstein guitar had no tone control for the same reason.
If you can hear your fingers coming out of the amp, you are on the right track. My Vintage Guitars |
#6 (permalink) | |
Re: re EVH wiring
#8 (permalink) | ||
Re: re EVH wiring
Jake
"Them that don't know him won't like him, and them that do sometimes won't know how to take him..." |
It does make a difference
All of my Teles are wired up to bypass the tone control for the neck pickup. It was a vast improvement for all.
I found that I was always running the bridge with the tone backed off a bit and when I would go to the nck I was having to open it up. With that aside just the raw tone from the neck is more open, better sounding. It's easy too. You only have to move one wire.
...it's not the load that breaks you down it's the way in which you carry it. |
I get the idea about bypassing the tone control...
Doesn't the newer tone pot (that orignally came with the Delta Tone system) with that notch at wide open do the same thing? Isn't it supposed to be completely out of the circuit then? Is it really out of the circuit?
I'm full of questions, huh? There I go again! Adam
Why yes, I do have a liberal arts degree...do you want fries with that? |
