Reverse controls: pros and cons
My first tele ever is a homebuilt, a partscaster. My friend George gave me the wood for the body, and he did the wiring. George likes the controls reversed--as I've seen on a few of the teles here--so that the volume knob is closest to the neck, and the pickup switch farthest away. I went along with that, and I'm happy with it.
But I've never had a tele before, so I wonder: is there a downside to reversing the controls, and if so, what is it? If there's not, why don't more people do it?
viva yo |
It's not just a matter of flipping the plate around. You also have to switch the pots around as well. There is likely some soldering involved. Other wise your tone pot is up front... and who wants that.
Creator of Fine Sawdust and Expensive Kindling. |
Doesn't really matter. Especially since your not used to the convention tele controls. If you play that guitar often enough you'll get used to it and that will be your norm. Easy enough to switch back if you don't like it.
I'm a lefty and played more Gibsons in the last 20 years than Fenders. Well Gibson installs the vol/tone pots so they rotate backwards on their lefty's. I'm so used to that I have to change the pots on Fender style guitars to also rotate "backwards". |
I've had mine "reversed" for 30 years and still haven't found one single reason to change it back.
Alvin http://www.myspace.com/alvinblaine http://www.oldbluesound.com/about.htm http://www.facebook.com/cowboytwang _________________________ Originality is just undetected Plagiarism! |
#8 (permalink) | |
7x555x 6x574x 6x466x 5x665x |
That mod is the best thing I learned from the TDPRI:
![]() I'm always reaching down to adjust the volume, and I love doing volume swells. The pickup selector switch is not too far for me but I admit that it took some getting used to and it made me realize how much I switch positions. The one con is that it's hard to do tone swells with the neck pup engaged because the switch is right next to the tone knob. But that isn't much of an issue because I hardly ever do tone swells. |
All 3 of my Tele style guitars have the plate flipped. Any of my pro's have already been mentioned.
Another con: not 'traditional' (if that bothers you). Here's my latest build - a lot of 'not traditional' going on here...
#13 (permalink) | |
I think you are actually supposed to swap the pots too, so that the volume is closest to the neck.
Turn it on, turn it up, turn me loose. |
#18 (permalink) |
can we have more pics? it is very much like something I have in my head.
sorry. on topic- I use the switch way too much to move it that far back. Strats and all, you know.
"Kid, it takes a long time"-Danny Kalb to me in NYC, 1992 |
#19 (permalink) | |
http://www.tdpri.com/forum/tele-home...r-esquire.html |
#20 (permalink) |
It all depends on what you like!!! I prefer my Teles to have the control plate in the normal way. That is just what I like. You have to do what makes you happy and who cares what someone else might think> Rock on brother.
#22 (permalink) |
Location: I can hit the Pacific Ocean and/or Canada with a rock from here...
Tried it flipped around, but I just couldn't get used to it, and that was back when I just dimed everything.
Since I've been playing Esquires almost exclusively for the last ten years or so, I use the switch and tone control quite a bit, but still find reversed plates feel 'wrong'. I seldom use the volume control at all- I just vary my pick attack for volume changes. Still, I want that knob in the traditional position... -Michael Charter Member S. Texas He-Man Emoticon Haters Local #316
Just an analog boy in a digital world... |
#23 (permalink) |
It seems from the responses so far that it comes down to whether you use the volume control or the switch more often. Decided on that and I think you'll have your answer.
Personally, I use the switch a lot more often, although it did take a little while to get to the point where I wasn't accidentally knocking it out of position with every down stroke. |
#24 (permalink) |
I use the switch and the volume a lot. I was always hitting the switch with my hand while I was playing and getting into the wrong pickup selection. I saw a photo of some fancy high-end Fender that came from the factory with the plate reversed and it was an a-ha for me. I flipped the plate, had to rewire some stuff (moving the volume away from the switch is problematic for stock wiring), but can't imagine going back. 5 years on, it's absolutely necessary for me.
#25 (permalink) |
I switched mine for a while, but I kept reaching for the wrong thing at the wrong time. I switched it back because I couldn't get used to it. Guess it's the "old dog, new trick" thing. I have my right foot on a volume pedal much of the time, anyway.
"......gotta keep rockin' while I still can....." - Steve Earle www.myspace.com/rugtheknuckleheads |
#26 (permalink) |
I far prefer the reversed.
As for rewiring, I was able to reverse without rewiring at all. Thing is, the wires to the switch are not long enough to mount the switch "right", so when the switch points back, it's on the neck pickup, and vice versa.
#27 (permalink) |
i tried the flip, but still wasn't satisfied. so i went with a switch-in-the-middle config, which i've come to love. (this one was made by Taipan.) vol control's right there where you need it, switch is still handy, and tone can be easily grabbed with the little finger. the custom design also allows a little more real estate between the knobs and switch.
#28 (permalink) | |
It's not a hard mod to do, but I had to replace one of the short wires with a longer one so some soldering is involved. |
#29 (permalink) | |
#30 (permalink) | |
![]() ![]() ![]() The Strat set up makes a lot of sense, both the selector and the volume knob are easily within reach and I find it easier to do volume swells on a Strat. Then again I started playing electric on a Strat copy. |
#31 (permalink) |
My 95 MIJ Tele deluxe came reversed with the volume closest. Don't know any other way as it is my only Tele ever played.
#33 (permalink) |
There's no downside if you're looking to keep your volume under your little finger all the time. Great for swells and steel guitar country licks. Also good if you find yourself throwing the selector accidentally on heavier strummed rhythm pieces. Bottom line in my opinion (and that's all it is) is that if the selector at the neck side of the plate doesn't work for you, you can either change your guitar to work with your play, or change your play to work with your guitar. I rarely hit my selector on rock/heavy metal rhythm stuff, and I use a volume pedal because I just haven't gotton those volume knob swells to sound right yet.
#34 (permalink) |
I like woodman's approach! But yeah, it really depends on whether the pickup flip or the pinky/knob relationship is the bigger deal. Reversing the plate is first order of business on my end. Don't listen to me though, as I want an electric guitar to sound like a Tele and feel like a Strat.
| LSR Roller nut, pros & Cons? | PK | Stratocaster Discussion Forum | 6 | May 9th, 2007 11:48 AM |
| Baseplates: Pros and Cons? | aaron6789 | Just Pickups | 17 | January 21st, 2007 11:33 AM |
| Pros and cons of a '69/'70 Tele? | skiraly017 | Telecaster Discussion Forum | 0 | August 17th, 2004 10:16 PM |
| Cab impedance pros and cons | Scotty Les is More | The BASS Place | 4 | May 10th, 2004 08:28 AM |
| Reverse control plates - pros & cons, options & opin | Tim Bowen | Tele-Tech | 8 | April 3rd, 2003 04:38 AM |
