Old January 29th, 2009, 09:10 PM   #1 (permalink)
Trimac20's Avatar
Epiphone Sheraton - input jack has fallen inside the guitar!
Hey all, haven't been here awhile, been really busy. Haven't played guitar as much as I've wanted to.
Anyway, in a pickle and wondering if anybody can help. The screw holding the input jack got lose and somehow came off along with the washer, and the jack itself has fallen inside the semi-hollow guitar. The Sheraton has two thin F-holes, and there's no way to get my hands in there. Wondering if I should unscrew the pickup covers and get it through that cavity, or if there's a way to somehow fish out the jack through the F-holes, with magnets or something. Just wondering if any of you folks had an idea, thanks.
Trimac20 is offline   Reply With Quote
Old January 29th, 2009, 09:29 PM   #2 (permalink)
mistermullens's Avatar
Same thing happened to me when I had my Casino. The difference is a Casino is completely hollow where your Sheraton has a center block that the pups are anchored into. I was somehow able to get some needle nose pliers in the jack hole and into the jack itself. I "opened" the pliers so they would be flush against the walls of the jack. Then, I very gently pulled it through the hole. Took a couple of times but I got it. Maybe not the best way, but it worked for me.
Jonathan ReverbNation Twitter Teles & Esquires
Old January 29th, 2009, 10:46 PM   #3 (permalink)
PeteMac's Avatar
Same thing happened to a mate of mine a couple of weeks ago, about 5 min's before he was to hit the stage!!!
He borrowed another guitar, and sent the Sheraton to his "fixer" the following day, so I can't really give any help as to how it's done I'm afraid.
Life is short; play loud!
www.myspace.com/theskinnersband
www.myspace.com/theboneyarsedboys
PeteMac is offline   Reply With Quote
Old January 29th, 2009, 11:32 PM   #4 (permalink)
gtrplr's Avatar
Use a stiff wire with a loop to fish the jack through the f-hole. You can snag one of the wires connecting the jack with the toggle switch and pull it through. Run the wire through the f-hole and out the output jack hole. Use the wire to pull a length of string back through the output jack hole and up through the f-hole. Be sure the string is long enough so that when it is pulled through the f-hole, it still lies outside the output jack hole. Tie the string around the output jack where the nut would normally go and pull it back through the f-hole and out the output jack hole. Begin to thread the nut onto the output jack. Once it's started, remove the string and then snug the nut down.
I work for Epiphone, and have done time in the repair dept. That's how we do it over there. It sounds a little complicated, but it's really not. Just a little tedious. Remember, patience is a virtue.
Randal Smith alias Smitty the Kid
"I'm so much cooler online."
gtrplr is online now   Reply With Quote
