Which bridge gets the most sustain?
I was looking at different guitars and was wondering out of all the different bridge designs, which one seems to get the most sustain? String through hardtail, stop tail, something else?
Its not the bridge itself but the way the guitar is made.
A setneck like a Les Paul will usually have more sustain than a bolt-on neck like a Strat or Tele.
I'm so blind my seeing eye dog needs glasses. |
I have a sneaking suspicion that it isn't the set-neck of the LP that gives it more sustain than a bolt on neck, but rather the fact that an LP has the same density wood used in both the neck and the bulk of the body.
Fenders have very hard neck wood and softer body wood. Transfer of sound waves through varying density materials often results in a loss of energy. Same reason density variation in Telecaster body wood or slack truss rods might account for "dud" guitars. But who knows?
i'm no expert, but i am impressed by the sustain in G&L models with the saddle lock bridge - played my nephew's gibby lp a few years ago and it can't hold a candle sustain-wise to my G&L - it took leo a while, but he finally got the fixed bridge right when he was at G&L - ymmv -
- i'm not a complete idiot ... some parts are missing - |
Going back to my original question and trying to add to it to get where I was trying to go, if the type of guitar was the same, which bridge would offer more sustain. Hypothetically speaker here, if I had several guitars, lets say all of them are Les Paul Customs, but one has a string through hard tail bridge via Fender, one has a Wilkinson tremolo, one has a Floyd Rose, one has a stop tail style bridge, and any other bridge designs you can come up with tho retro fit or custom install on a guitar. In this hypothetical world, they are all perfectly the same except said bridges. Which one should have the most sustain?
I did see a video of Carlos Santana playing that explained his "sustain" a little better to me. He normally plays with his volume about half way up on the guitar. Then, when he hits a note he wants to sustain, he slowly rolls the volume up to keep the note the same volume instead of it decaying. Of course that video he was playing a Mesa Boogie. Has he been using a Dumble for while? The video I saw was from around 1993.
The one that's on a guitar plugged into a decent compressor.
http://www.myspace.com/jameswilsey |
As said here, bridges by themselves do not control sustain; they are part of a system. However, they can have an effect - I have tried replacing the old traditional 3-saddle bridge on my 52RI with a heavy cast bridge (Allparts) and the guitar behaved VERY differently - most definitely more sustain.
Also a much less interesting tone, flattened out. The bridge came off within a couple of days and the original was put back. Much more interesting as a musical instrument, IMHO. Sustain comes at a price.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
#16 (permalink) |
http://816rocks.com/ |
#19 (permalink) | |
#20 (permalink) | |
A plucked vibrating string has a limited amount of energy. The laws of physics determine that each succeeding vibration of the sting after plucking gets weaker (unless its being acted upon by an outside fource, such as feedback, etc). A bridge of any type is not going to give it more energy, but something light and flimsy may cause it to lose some energy. An old Gibson type 'wrap around' non adjustable compensated bridge mounted on heavy studs may have the 'most sustain'. Not sure. ![]() Or a hardtail strat type bridge mounted into the wood with a string thru body arrangement. Better yet, inlay a big block of heavy hardened steel in the body and mount the bridge to that. In any case- the amount of things you can do to a guitar itself to affect 'sustain' are basically negligible. If you are chasing a the archetypal 'rock sustain' sound, that is 99.999% a function of the output device chain: especially distortion, compression, and amplifier. With the 'right' output chain, you can make the flimsiest Danelecrto masonite guitar with thin strings and low output pickups 'sustain for days'.
#21 (permalink) | |
A T.O.M would suit this hypothetical Carvin well in MHO.
#23 (permalink) | |
Yes, but the caisson style construction is a real tone sucker. ;) |
#24 (permalink) |
OK. I think I've got a good enough idea at what I was looking for, but now you've got me wondering. What is the actual radius of the Brooklyn Bridge, and did they use a compound radius?
#26 (permalink) | |
In practice, a small amount of energy is dissipated into the air. Most of the energy loss takes place at the frets and saddles. That energy vibrates the neck and body and produces the acoustic sound of the guitar. Note that the louder a solid body guitar is acoustically, the less sustain it will ha |
