Old July 17th, 2008, 03:05 AM   #1 (permalink)
okay for strap buttons to be loose??
this might be a totally stupid question, but is it okay for the bottom strap button to be a little loose? im talking about this to ease my mind.. since i lean my guitars against things alot and some of them have tall buttons that puts all the pressure on that one point. i know its stupid.. but how safe is it for a 8, 9 pound guitar to have a loose strap buttons?
aznxtasy341 is offline   Reply With Quote
Old July 17th, 2008, 03:09 AM   #2 (permalink)
rhinocaster's Avatar
Loose means "On its way to falling out".
It's not OK for the buttons to be loose. Take the screw out, fit 2 toothpicks in the hole with wood glue on them and let dry. Re-install the screw.
You should be good to go.
Just because I "Don't" get it doesn't mean I "Won't" get it!
rhinocaster is offline   Reply With Quote
Old July 17th, 2008, 07:36 AM   #3 (permalink)
BAW4742's Avatar
Fix it. It's an easy fix so no reason for loose strap buttons.
If it's not too loose rhinocaster's tooth pick trick will work. I've fixed over sized holes by gluing in a golf tee and re-drilling after it sets up.
BAW4742 is offline   Reply With Quote
Old July 17th, 2008, 01:29 PM   #4 (permalink)
boris bubbanov's Avatar
Not okay. Fix it now.
Bubban0v
boris bubbanov is online now   Reply With Quote
Old July 17th, 2008, 02:38 PM   #5 (permalink)
Here's what I do for loose strap buttons (that is, if they won't tighten, sometimes you just need to screw it back in).
Fill the whole with wood glue, then insert a match backwards and break it off at the surface of the guitar. Wipe off the excess glue from the guitar and then let it sit for a few minutes. You want the glue to be a little hardened but still gooey, 5 minutes is good.
The just push the screw into the hole a little and screw it back in. The mush of wood and glue is very strong and has never needed to be done again on any of the guitars I've done it too.
Fender 52RI - Gibson SG Standard
'77 Deluxe Reverb
SunFace w/ Sundial - ProCo RAT - Fulltone GT-500
Keeley AD-9 - Boss CH-1
hamish5178 is offline   Reply With Quote
Old July 17th, 2008, 02:43 PM   #6 (permalink)
magicguitar's Avatar
+1 to fix it now!
magicguitar is offline   Reply With Quote
Old July 17th, 2008, 02:45 PM   #7 (permalink)
ajgus's Avatar
+1 to everything said. I would also advise that maybe you should invest in a stand either of the floor or wall-mount variety. Its ok to lean your guitar up against your amp every now & then, but it only leads to the potential for problems in the long run.
"I'm still married to my first wife...and that's my first guitar...she don't talk back to me, she talks for me..." -Stevie ray Vaughan
ajgus is offline   Reply With Quote
Old July 18th, 2008, 12:30 AM   #8 (permalink)
Tighten it up now.
Originally Posted by nasonm
I like my guitars to look like big wooden pieces of candy!
http://www.soundclick.com/bands/page...?bandID=649738
teleman65 is offline   Reply With Quote
Old July 18th, 2008, 11:02 AM   #9 (permalink)
It's perfectly fine to have loose strap buttons... as long as you are perfectly fine with having your guitar fall off the strap one day while you're playing.
Otherwise, fix it.
tpaul is online now   Reply With Quote
Old July 18th, 2008, 11:20 AM   #10 (permalink)
Arlo's Avatar
If it's a relic look you are seeking your on the right track.
Of course it might interfere with the solo during Purple Haze.
My music? It is free for my friends.
Arlo is offline   Reply With Quote
Old July 18th, 2008, 11:53 PM   #11 (permalink)
Tim73's Avatar
I've used bits of matchstick in the past to rectify the problem
Born in the '70's & in my mind, still living there now...
Tim73 is offline   Reply With Quote
Old July 19th, 2008, 11:44 AM   #12 (permalink)
bowlfreshener's Avatar
If you must ask yourself if its okay for strap buttons to be loose, then you must ask yourself is it okay for your guitar to fall off and hit the floor?
As everyone suggested, the matchstick or toothpick method should work unless you have gouged out a larger hole with the loose screw. I check all the strap buttons and stuff that can come loose before I play, much like I would give my car a quick look-check before I start driving...
RAMA LAMA FA FA FA
bowlfreshener is offline   Reply With Quote
Old July 19th, 2008, 12:15 PM   #13 (permalink)
Romeo Rose says No problem!
tc6969 is offline   Reply With Quote
