fundraiser
Old May 15th, 2008, 10:00 AM   #1 (permalink)
HoodieMcFoodie's Avatar
Humidifiers. Who, what, where...
G'day folks,
I've been hearing a bit lately about humidifiers and guitars, but I'm totally clueless about their applications.
Can someone please explain to me when, where and why you would need to humidify a guitar? Also the difference between leaving guitars out of the case or in their case. What are the pros and cons of either?
Regards,
Hoodie
HoodieMcFoodie is offline   Reply With Quote
Old May 15th, 2008, 10:07 AM   #2 (permalink)
My personal opinion is they are a waste of money.
To look after your tele the only thing you have to do is try not to let it fall into a wood-chipper.
Cases are handy as they have handles which stops you from dropping the guitar into a wood-chipper.
R
rcalverley is offline   Reply With Quote
Old May 15th, 2008, 10:15 AM   #3 (permalink)
Humidfication is a concern for acoustic guitars but not solidbody electrics. During the winter home environments often are quite dry and this can cause the wood of an acoustic to dry and crack. This is more of a concern in places with cold winters. Keeping your acoustic in its case with a humidifier and refilling it as necessary will prevent this type of damage.
Your telecaster doesn't care though.
symbiotic is offline   Reply With Quote
Old May 15th, 2008, 10:30 AM   #4 (permalink)
KevinB's Avatar
Unless your live where you see extreme swings of temperature and humidity, a humidifier shouldn't be needed for a solid bodied guitar like a Tele. Quality acoustics are another matter though. Here in the northeast USA we get very cold and dry winters, and even with a central humidifier connected to my home heating system, keeping the house much above 30% in Jan and Feb is a problem. Subjected to this level of dryness, solid wood acoustics stand a very good chance of cracking.
Room humidifiers are available (I use one for the room my guitars are kept in) for about $80-$100 although they must be filled with water every few days. A simpler solution is to keep acoustics in their cases and use a soundhole humidifier, like a Dampit.
As to whether or not to leave guitars in their cases, well I don't have little kids running around (my dogs know better!), I keep my guitars in a dedicated room, and if I leave them cased I tend to play less. So, mine are all out on stands.
Old May 15th, 2008, 10:32 AM   #5 (permalink)
maestrovert's Avatar
Don't let 'em kid ya, solidbody guitars are affected by drier than normal conditions, though not to the same extent as acoustics....you may see "fret sprout" and may also need to make a truss rod adjustment come winter time....
When i moved from S. Florida to central Michigan this past Feb., i definitely DID notice that the drier conditions (due to central air/heating) affected all of my stringed instruments -both acoustic and solidbody- to some degree....so for myself, come next winter, i'll be runnin' the humidifier Thank you....
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old May 15th, 2008, 11:01 AM   #6 (permalink)
mildwild's Avatar
This year I had a very small ( but noticeable ) fret sprout on my James Burton.
A 60's Classic in the same room wasn't affected though.
I was more concerned for the grand piano ( 1920's) in the room so I bought a room humidifer that so and within 2 weeks it was gone.
It was a cold winter and the furnace was on alot and this year was I first noticed a difference.
mildwild is offline   Reply With Quote
Old May 15th, 2008, 03:18 PM   #7 (permalink)
Vizcaster's Avatar
"Don't store your guitar in any room you wouldn't be comfortable yourself." Tee hee. Good thing that rule doesn't apply to venues.
Old May 15th, 2008, 04:05 PM   #8 (permalink)
mildwild's Avatar
I was comfortable in my living room till I felt some fret sprout.
Old May 15th, 2008, 07:20 PM   #9 (permalink)
sdcb27's Avatar
+1
I have noticed tuning changes depending on the humidity of weather. When my accoustic goes a little out so is my tele. Under normal and steady conditions neither change. Wood is wood after all.
I have seen a 3 inch thick sealed peice of wood check and split severly due to a heat and humidty change within a one week period.
Romey
Keep a light rein, a foot on each side and a far away look
sdcb27 is offline   Reply With Quote
Old May 15th, 2008, 09:47 PM   #10 (permalink)
boris bubbanov's Avatar
Thank you for weighing in. I knew your move would put you in the better position to say than most of us could say.
I know in Louisiana and Florida, I don't need one, but these arid West guitars and freeze dried Northern guitars, you should be cautious.
Bubban0v
Old May 15th, 2008, 11:11 PM   #11 (permalink)
mellecaster's Avatar
As the 2 Gentlemen above have stated, all Guitars benefit from proper humidity...electric and Acoustic, last time I checked they were both made of wood ???...but what I don't understand is why some of you don't think about yourselves, and your Family...who the Hell wants to spend all winter gettin shocked from the carpet..have your nasal membranes feel like Iraq...and yer precious Pets wheezin ???...Humidify your Home if needed....It just don't seem that complicated to me...Folks have been doin it for years.
I have never owned an Ipod or Blackberry..and doubt that I ever will......
Old May 16th, 2008, 10:15 AM   #12 (permalink)
OK, so it seems that solidbodies as well as accoustics (& grand pianos) can be affected by humidity.
So for me now the questions are;
"How do you determine if your guitars are being affected by humidity?"
"How do you measure the level of humidity in your home?"
"Is one room better than another for storage. ie, Is a warmer room better or a cooler room?"
Thanks for all your input.
Hoodie
Old May 16th, 2008, 02:31 PM   #13 (permalink)
sdcb27's Avatar
Hoodie
I bought a thermometer that indicated humidity, pretty inexspensive. Its real dry in the west where i am as otheres indicated so i cant keep a perfect guitar humidity going,house sucks it up quicker then a guitar but i can get it close enough that guitars stay in tune. The humidity gauge i got is a indorr/outdoor, so it has a lead i can put inside a guitar case if needed, if one had too
Romey
Old May 16th, 2008, 02:42 PM   #14 (permalink)
gibsonjunkie's Avatar
Try one of these...
I have an older version and it works great - temp and humidity and it stores the high/low settings so you can see how much fluctuation there is in temp/humidity.
actually, this one looks better...
The early bird gets the worm, but the second mouse gets the cheese...
gibsonjunkie is offline   Reply With Quote
Old May 16th, 2008, 03:50 PM   #15 (permalink)
mildwild's Avatar
I have a Planet Waves like this
http://www.guitarcenter.com/Planet-W...16-i1134007.gc
Old May 17th, 2008, 05:09 AM   #16 (permalink)
Living in Indiana, where we run the furnace several months out of the year, will cause my guitars to dry. I could not get a long with out a humidifier.
If you live where humidity levels can go very low becuase of running the furnace etc., you should get a humidifier. Changing humidity levels can affect all guitars. There are many kinds of humidifiers. Some fit directly to the furnace. Others can just be placed in the room or even in the guitar case.
When people complain about their frets sprouting, it is time to treat the guitar. You will see the fretboard expand after a period of time. Usually within a few weeks, your guitar will be back to normal.
Too much humidity will also cause problems.
nvosmeier is offline   Reply With Quote
