Old April 30th, 2008, 11:57 AM   #1 (permalink)
TheGoodTexan's Avatar
Found a GREAT automotive wheel cleaner
Yep...Easy Off Oven Cleaner
I've always been frustrated by the poor level of success of most commercial wheel cleaners. They're generally expensive, and never have I been able to just "spray on / spray off" and end up with clean wheels. I always have to get down and scrub to some degree....and if I'm going to have to scrub anyway, why am wasting $6 on a spray bottle of "cleaner"?
Then I saw the Easy Off at the grocery store the other day...and it dawned on me. I bought a can for $2 and tried it. And the stuff freakin' works.
I knew that it was extremely potent stuff, and very capable of causing damage to my wheels if I left it on for too long, so I prayed some on the front wheel, then on the back wheel...counted to 10, and rinsed it all off with the garden hose. and....VOILA! Factory-clean wheels. Perfectly clean, with no damage what-so-ever.
I will add that I have factory clear-coated wheels on my truck, with plastic center caps, just like these:
I did rinse them for an extra few minutes, just to make sure that there was no residue left that might cause damage later on.
Originally Posted by Sidney Vicious
If there's anything worse than whining its whining that your whining isn't being heard.
TheGoodTexan is offline   Reply With Quote
Old April 30th, 2008, 12:13 PM   #2 (permalink)
Moderator
getbent's Avatar
I looked up the ph of easy-off and it looks like it is about 13.5 which is not too rank... so the good news is that chemicals that raise the pH to such a high degree (called bases) applied to most metals quickly remove oxides and organics. Bases love organics like meat, flesh, eyeballs...etc. The potentially bad news is that unless you totally clean every molecule of a caustic from the surface, the base will pursue positive ions wherever it can find them. If it finds free ions it will form a salt. It will pursue metallic ions from molecular metals if it can't find a handy oxygen molecule. It will discolor or tarnish or etch or erode most kinds of metals.
A safe (for you and the car) way to neutralize a strong base is with a lot of water. Don't use any acid, you already know what happens when acidic material comes in contact with metal.
Wash with soap. Wash the area to which you applied the base then wash everywhere that water splashed when you rinse it off. Then rinse everything again.
I think it is a cool idea... it will be interesting to see how it looks in say, August... report back!
Old April 30th, 2008, 12:13 PM   #3 (permalink)
g-Paul's Avatar
Let me know in a week if they're still ok!
Actually, I doubt it could be harder on the wheels than all the salt they put on the roads up here.
g-Paul is offline   Reply With Quote
Old April 30th, 2008, 12:20 PM   #4 (permalink)
getbent....you're always the kill-joy, eh?
Old April 30th, 2008, 12:21 PM   #5 (permalink)
Moderator
Tim Armstrong's Avatar
I spent a lot of time cleaning with caustics and acids as a brewer, and I'd say that, after a whole lotta rinsing with water, a weak acid rinse (some vinegar in a hose-end sprayer, perhaps) will safely neutralize whatever caustic is left. I'd follow that with one more water rinse...
Cheers, Tim
http://www.moodswingers.org
Tim Armstrong is online now   Reply With Quote
Old April 30th, 2008, 12:23 PM   #6 (permalink)
I will add that I used my pressure washer to rinse with....so I feel fairly confident that I was able to remove 100% of the Easy Off.
Hmmm...I wonder what other uses that Easy Off has?
Old April 30th, 2008, 12:39 PM   #7 (permalink)
1293's Avatar
It's great for getting soap scum off an enamel tub.
1293 is offline   Reply With Quote
Old April 30th, 2008, 12:50 PM   #8 (permalink)
Moderator
getbent's Avatar
GT, I would never want to be a killjoy! If you used your pressure washer and lots of water, I'd bet you are fine.
I'm thinking of trying easy off on some stuff around here... and maybe on some stuff I wanna throw away... I won't wash off too well! (I strongly suspect that my wife occasionally adds too much bleach on my old sweatshirts to decrease their usefulness!
Old April 30th, 2008, 01:55 PM   #9 (permalink)
boris bubbanov's Avatar
The factory wheels on the 4K miles otherwise mint 2001 Saab 9-5 Aero I found for my girlfriend Memorial Day 2006 had etching on the wheels from these types of products. Otherwise it'd have been prefect. Eventually I'll repaint the wheels.
I guess that's the only thing I don't like about these BBS style wheels I have on my 2004 9-5 Arc is that it takes a lot of time to keep them clean; I'm substituting a less dusty brake pad set I bought from Satisfied (Pro Ceramic VS) but after 48K miles the stock pads still are just too fresh and fat.
Bubban0v
Old April 30th, 2008, 02:28 PM   #10 (permalink)
1293's Avatar
I hope that works out for you. I put some Mintex semi-metallic pads on my car and it is SCARY when they're wet. I step on the brake and I've got nothing. Then one wheel dries out before the others and the car pulls one way or the other.
Old April 30th, 2008, 02:37 PM   #11 (permalink)
Moderator
getbent's Avatar
anybody tried carbon kevlar brake pads? I know lots of car nuts use them to reduce 'brake dust'.
Old April 30th, 2008, 03:07 PM   #12 (permalink)
Would this stuff help with brake fluid discolored wheels? First service on my old ducati, those yahoos let brake fluid (or maybe clutch fluid drip on the gold tinted rims (some heavier than aluminum alloy). I never noticed until too late. Dark spots now. If I buff hard enough, the tint comes off as well as the spot.
mad dog is offline   Reply With Quote
Old April 30th, 2008, 03:14 PM   #13 (permalink)
1293's Avatar
I wouldn't do that. I used Easy Off to try and get some cooked-on gunk off an anodized stock pot and it ruined the finish.
Old April 30th, 2008, 07:57 PM   #14 (permalink)
red57strat's Avatar
I won't even use anything as harsh as wheel cleaner on wheels.
About 15 years ago I used a wheel cleaner on my wheels, didn't rinse it well enough and ended up with radial streaks permanently bleached into the wheels' finish.
I used to use oven cleaner to strip paint off of model cars. I wouldn't go near my wheels (or my tires) with it.
Don
red57strat is offline   Reply With Quote
Old April 30th, 2008, 08:25 PM   #15 (permalink)
teledude66's Avatar
Keep us informed it sounds good to me, but I too wonder about long term. However I may use it on my motorcycle to get some old grease and oil buildup off, I paint it back black wrinkle finish so no biggie there.
The fact that no one understands you doesn't mean you're an artist.
teledude66 is offline   Reply With Quote
Old April 30th, 2008, 08:26 PM   #16 (permalink)
AnthemBassMan's Avatar
-I know a girl who uses it to remove old paint from woodwork in homes. She said it works better than other strippers she's tried. I just don't know about people who would paint over beautiful oak, maple, cherry etc...
L8R,
Matt D.
AnthemBassMan is offline   Reply With Quote
