Do mini-humbuckers fit in a p-90 soapbar route?
I am lookign at swapping out a bridge P-90 with some variation of a humbucker. Do mini-hums like on a Firebird fit in a standard soapbar P-90 route?
Are there any other options out there for a soapbar sized humbucker? |
| Sponsored Links |
Moderator
The original Gibson mini-humbuckers were fitted to plastic trim rings that were the exact same size as P-90 covers (and were probably cut from them!), so if you get the traditional mini trim rings, you oughta be just fine!
Cheers, Tim
http://www.moodswingers.org |
#10 (permalink) | |
Do a search for 'Gibson Les Paul Deluxe' pictures and you'll see the minibucker pickup rings. You might be able to find a company online that will sell newer versions of those rings, if they aren't included with the pickups you purchase. |
#14 (permalink) | ||
The mini-hum mounting rings that were made from P90 shells do not mount to the top of the guitar, but rather, in the pickup route itself. The entire mounting ring/shell slips into the route perfectly. ![]() Then there are the regular minu-hum mounting rings that are just smaller versions of their full-size brethern....and those do indeed mount to the top of the guitar.
#16 (permalink) |
Tex,
Thanks for the info. But how do the P90 rings mount to the guitar then? I mean, the two visible screws attach the pickup to the ring and offer height adjustment, right? Or do these screws go into the body at the bottom of the pickup rout? |
#17 (permalink) | |
I think a little L bracket gets installed on each side of the route. Allparts sells them IIRC. Or I have seen a one piece that screws into the bottom of the route ala LP Deluxe. You could just use a piece of flat stock flat in the bottom of the route and drill and tap for the PUP screws. Picture worth a 1000 words: |
#18 (permalink) | |
Yeah...that's exactly right. Sorry I didn't explain that.
Those two mounting holes on that flat bar...should be in the same spots as the mounting screws for P90s (soarbars of course, not dog ears). We're using 1000 words here to describe something that is easily figured out in a few minutes by even the least mechanically inclined one of us.....if you just had all of it in front of you.
#20 (permalink) | |
![]() I've been trying to confirm the age of my LP for a while. I also can't compare it to other models easily because it's had a neck repair and the headstock is different than any Gibson model or other replicas. Does anyone know how many LPs rolled out with these nailed on trim rings? And when these were actually used? That might help me narrow down the age my my guitar. Best! Drew |
