How long to humidify a guitar with a room humidifier?
I had been having fret sprout problems for the first time ever on my acoustic - it was suggested that I get a humidifier (an in-case humidifier was suggested, but I don't have a case for the guitar). I was at Wal-Mart yesterday and noticed they had a close-out price on a room-sized humidifier. I bought it and started running it this morning.
My two questions: 1. If the guitar soaks up enough of that moisture, will the fret ends go back to where they're supposed to be, or will I still need to take it to a guitar repairman to get them knocked back into place? 2. How long should it take for that guitar to reach maximum/ideal moisture levels in a humidified room?
Every now and then I know it's kind of hard to tell, but I'm still alive and well. |
| Sponsored Links |
I don't know about acoustics, but I'll render my strat experience. I had a rosewood fingerboard strat, and last winter, my house got down to 11% humidity. One day, I picked up my strat, and ouch, thought I was in GC or Daddy's Junky Music for a moment.
It took 4 weeks in a 45% environment, and still needed ever so slight a filing. I mean, 2 or 3 light passes with a fret file. That is why I now have a 12 gallon whole house humidifier. I'd like it around 40-45%, but 30-32% is a darn site better than 11%. Next winter, I'm getting a dedicated guitar room unit and hygrometer, just didn't have the scratch to get it this winter. |
I just bought a humidifier after I could feel the frets on my James Burton Standard.
Also I was very concerned about my old grand piano. Humidity was 27 % The humidifer I bought you can set the humidity level you desire. After about 2 days set at 45 % there doesn't seem to be a problem anymore. |
Thanks, guys. Guess I'll let the humidifier run and see what happens. I probably should oil the fretboard. I've never done that before, but the guitar is only 15 years old.
I need to get a different brand of lemon oil. The one I have stinks but it keeps the fretboards safe. I had some before that smelled good. It's pretty cheap but I just haven't looked at all.
You just get a clean rag and soak a little into a spot on the rag and rub it in then let it soak in the fretboard overnight. You can tell just by looking at the board if it needs it. It'll be a real light colored brown- (dry looking).
In Brett We Trust. |
What kind of furnace do you have? When I lived up north I had a gas forced-air furnace. I added a humidifier to the furnace for about $150, and it not only helped my guitars, it allowed me to set the thermostat a few degrees lower and still be comfortable. I thought it was a better solution than a room humidifier, and it didn't cost too much more.
Prior to getting the humidifier, the problems with guitar frets were pretty minor. Once I got it, they went away entirely. I can't tell you how long it took. http://www.aprilaire.com/index.php?z...ory=5&item=500
http://www.CharlesOffer.com Last edited by CharlieO; March 22nd, 2008 at 08:05 AM. |
here's my experience....
since about half of my repair work in the winter consists of acoustics with just this problem. The other half is the body has shrunk due to lack of humidity.
The answer to how long it will take is, "it depends". Since your guitar is made of different of types of wood, and finish types vary as well. So, if it took a month or two or three for the wood to lose the moisture.... you won't really know how long it takes to rehumidify until your guitar is back where you want it. In the winter time, just leave the humidifier running all the time to deal with fret sprouting. Don't worry about knocking the frets back in. For a quick rehumidifying experience for a shrunken body, loosen the strings & lay the guitar out flat on it's back. Take a plastic bag and spread it out inside the guitar under the sound hole. Take a washcloth and get it wet (not sopping wet). Microwave the washcloth for about 25 seconds. Put that in the soundhole of the guitar laying on top the plastic bag. Put another plastic bag over the shoundhole, beneath the strings. Come back in a couple hours and re-microwave the washcloth. Do this a couple times a day. Usually in a couple days the body has resumed the original dimensions and you are back where you wanna be. In extreme cases like this one Takemine I was working on last month, it may take more than a week for it to get back to playable condition. Don't over do it, take it slow. It didn't get that dry overnight, and it won't rehumidify overnight either.
I got them happy kind of blues |
#13 (permalink) | |
Glenn suggested leaving the room humidifier running all the time. I wonder what your electric bill would be if you did that?
http://www.CharlesOffer.com Last edited by CharlieO; March 22nd, 2008 at 09:49 AM. |
#14 (permalink) | |
I really should get a case for it. In the meantime, I'm hoping that a few days or weeks or months of sitting in a properly humidified room is going to help her out. Should I wait until it's back to normal to oil the fingerboard? Or should I do that before it's fully re-humidified?
You probably aren't going to see any change in 14-15 hours. Give it a few weeks and it will probably be back to where it should be, or close. Room humidifiers are kind of a hassle becuase you have to keep filling them up with water and keeping them clean so that you won't spread bacteria through the air.
Furnaces can be harsh to a guitar. It can hurt more than just the fretboard. |
#17 (permalink) |
Sean, I actually use orange oil on my fretboards every time I change the strings. It's pretty easy I just spritz a washcloth with the stuff and wipe it down. Re-humidifying a guitar? I did mine in about 2.5 weeks, with a humidifier in the guitar kept in a case. I have a whole house humidifier in the central air unit, in the winter I keep it at about 45%. However, I keep my acoustics in their cases so they need a little extra attention. The good thing about humidifying in the case is that you can easily tell when they're getting re-humidfiied, as you don't have to put as much water in the humidfier after a couple of weeks. I started out filling the thing every 2 days but after a couple of weeks, I only had to fill it about every three or four days then it didn't need much for a week then two weeks. Once the guitar starts getting rehydrated it doesn't suck it out of the humidifier at as fast a rate. Am I making any sense here? Anyway, it's a more controlable environment in the case.
New guitar case $40. New soundhole humidifier...$10. Acoustic guitar with no fret sprout, no cracks in the finish, and no pulled up bridge.....priceless. Mastercard for the things you need right now...... |
