| B-Bender Forum Bend your mind around the TDPRI's B-Bender Forum. |
hipshot on a tele with six saddles
messieurs, i am meditating the idea, of putting my hipshot unit to a guitar with six saddles. i am not making any progress with that idea, because i see no way to do it. has it been done before? eddie
Putting a bender on an non-American six saddle bridge requires that you replace the saddle with one that has an offset intonation screw and slot the saddle. After drilling a second hole in the bridge for the offset intonation screw and slotting the saddle, the B string passes through the existing hole and onto the slotted saddle. On an American six saddle bridge, you simply need to drill a second hole for the string and slot the saddle. Every once in a while you will see the slotted saddles advertised on Ebay. I'll try and post a picture later on.
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right." Iris Dement |
I put a Hipshot G-Bender on my P/W B-Bender equipped Tele, and it has 6 Graph-Tech/Mike Christian piezo offset saddles. It works just like Dogbear's P/G, except I cut a notch in the back of the bridge instead of the hole. It worked just fine!
The Demented 7th |
Eddie, yes it will. The procedure is just reversed. Since you have center tapped saddles, one would replace the B saddle with an offset one. It would require that you drill another hole for the offset intonation screw and use the existing hole for the string to pass through. The saddle would be slotted the same. It should look the same as the picture, but; all the other saddles would be center tapped. Sorry, I don't a picture of that installation.
