How far to bend a C#
How much travel should the string cap (bit that comes through the guitar with the string attached) have?
i want to be able to go from a B to a C# Its looking at the moment to travel only a few millimeters any info will be greatly appreciated. Will be trying to rectify it tomorrow. Chris |
![]() Tele-Meister
I think with a .012, a 'few millimeters' sounds about right. You could calculate how far the string pulls using your string gauges. Measure diameter of tuning peg string is wrapped on. Tune your B string, then count rotations of tuning gear to get to C#. That number of turns x 360, divided by 12 = degrees of rotation of peg (assuming 12:1 tuning peg). Deg of rot/360 x D x pie = string pull.
Tube-Tone Amplifiers |
Yeah building my own. hopeing to get it finished today fingers crossed. It moves a bout 3mm so i'll just try to get a string on the hub and try it. I thought it might not be enough but thats restored my faith.
Gudday!
Speaking as someone who has fooled (a lot!) with this principle in building my own modifications to a Bigsby Palm Pedal, can I suggest that the thing to measure is the travel AT THE CIRCUMFERENCE.... ....in other words, if you're not getting what you want, you have to re-consider the diameter of the 'peg' on which you're winding the string.. In the case of the design of your bender, though, I concede that there are limitations before you start to introduce serious alignment problems... I was lucky that the axis of my components was at 90 degrees to yours.. Good luck in getting it all together... sure feels good when it all works out!
Heaven: A Bassman 410, a good pizza, and a nice lie down |
Thanks guys.... i can tell you it works really well!! its strange to play at the moment so i think i need to get used to that.... but it pulls to a C# great and with a decent amount of travel.... i'll put up some pics in the other thred and link it to this one later.... maybe a vid in a few days... really cuffed with it.
Its got a tuning screw built into the top of the guitar that stops the arm moving up to much. its pretty tight to so it wont move about... been playing for about 2 hours on and off now and only had to adjust that once.
This is a link to the pictures in the other thread. (just so i dont have to re-post the whole story)
http://www.tdpri.com/forum/b-bender-...ml#post4144620 This is the finished guitar
