Old April 15th, 2012, 04:18 PM   #1 (permalink)
Newbie Making a B Bender
Hi everyone!!
I'm new to the forum (although been lurking for a few months) and thought i'd share a project i'm undertaking with my Dad.
we're making a b bender for a telecaster i picked up for cheap, Just thought i'd show what i've done so far and ask some advice.
So far We've:
-made all of the mechanism
-Routed out and made it fit (its a bit crude i know, but so was Clarence Whites first)
but i'm looking for advice on,
-how to set it up.
i'm concerned that the strap arm won't move enough to raise a B to a C#. From my understanding i should be able to move the rod to different points on either piece of metal on the inside, to give the string more movement in pitch and keep the same amount of moment on the strap arm?
I'm thinking how how much the "finger" on a steel guitar changer has to move to pull a string (i'm a steel player too btw), i can't tell right know if it will be enough...
Also how much tension should there be from the long tension spring? with a spring and the tension of the string... is that usually enough to stop the B going out of tune while standing up with a strap??? also any special kind of spring?
Any help would be appreciated, especially on the spring. I've looked though loads of the builds on here and seen a few different ways of making these over the months.
I know it may look a bit of a Clarence White clone... but its just the only £50 telecaster i could find...
I know the routing is a bit crude... i think we needed a bigger routing bit lol
next stage is to cut the strap arm down and fit a peg
find something for the string to go on
and sort out a tuning system for it.
Thanks,
Chris Hillman
www.cjhillman.com
CJHillman is offline   Reply With Quote
Old April 15th, 2012, 04:29 PM   #2 (permalink)
Colt W. Knight's Avatar
Looks like you need to take smaller bites with your router,and create a template.
the now mandatory =====>
Old April 15th, 2012, 04:59 PM   #3 (permalink)
yeah. it looks pretty rough on the photo, we just kinda went for it. it took a few hours to do all that. its a hand held router and the bit was tiny.... everything clears it on the inside and nobody will see it (he says after posting a photo of it haha)
Old April 15th, 2012, 05:09 PM   #4 (permalink)
Super Moderator
getbent's Avatar
I kind of like it.. sort of Flintstones meets Jetsons.
does it bend in tune?
The world is an amazing place. Go poke a whale."
nickjd
Old April 15th, 2012, 05:24 PM   #5 (permalink)
Haven't got that far yet lol. will finish it off soon. need some more bits
Old April 15th, 2012, 07:20 PM   #6 (permalink)
telex76's Avatar
I don't know how well it will work. I won't comment on how it looks.
But, Congrats on having the balls to go for it.
telex76 is offline   Reply With Quote
Old April 15th, 2012, 07:39 PM   #7 (permalink)
thanks dude, always wanted one.... i probably should have waited a while longer before posting pics to see if it does work lol. im sure it will after some tweeking. built a lap steel the other month with some "home brew" palm pedals... that works quite well.
Old April 16th, 2012, 08:33 AM   #8 (permalink)
asatfan's Avatar
Looks like you've got the right idea...who cares how it looks (it really doesn't look bad) as long as works! Let us know how it turns out.
Personally, I like the tension to be quite stiff, as to not bend notes when I don't want to (accidental bends)....some like it feather light.
Chris Hillman, huh?
"......gotta keep rockin' while I still can....." - Steve Earle
http://www.facebook.com/pages/Rug-th...s/112739214212
asatfan is offline   Reply With Quote
Old April 16th, 2012, 10:29 AM   #9 (permalink)
Cool!!
It's about playing, not beauty contests!!
KENNY POWERS for Precedent !!
Doug 54 is offline   Reply With Quote
Old April 16th, 2012, 12:38 PM   #10 (permalink)
I wasn't giving you a hard time about the looks of your guitar, but I did want to point out about your router technique. Taking those bigger bites like you did has a high potential for tear out and ruining the guitar body. Plus there is a bit of safety issue hogging out large portions of wood like that. Don't want you to loose a finger, I saw some of your videos, and your a good picker.
Old April 16th, 2012, 05:54 PM   #11 (permalink)
Thanks dude! i appreciate it. Its ok i didnt take anything to heart and thanks for checking out my videos.
hopefully get some more done around Friday. I think i'll cut the arm down and fit a strap peg next. not much time for anything else. I might look for a move heavy duty spring. i dont really want any unwanted bends.
I was guessing with the tension of the string as well, it might not need a really heavy spring but i duno?
Never played a b bender before so its tricky making something you dont know what it should feel like. I've noticed the newer ones that you buy tend to have a snappy pull on them... but the Clarence/Marty Stuart one has a longer bend... just from watching the youtube vids and reading a bit. so i'm hoping to get it a to have a longer slightly smoother pull on it.
Old April 17th, 2012, 10:41 AM   #12 (permalink)
HOBBSTER01's Avatar
I commend you for your efforts.
What are you using as a hub on the front side?
The Hobbster
"If you know "how" to play, a Peavey Bandit is all you need."
HOBBSTER01 is offline   Reply With Quote
Old April 17th, 2012, 03:38 PM   #13 (permalink)
Just bought a volume knob for a telecaster.... the idea is that i can use the screw/allen key on the knob to anchor it to the shaft... then attach a bit to put the string onto.
I had a pedal steel made buy ZumSteel that had little "prongs" to hook the ball end over... so thats idea i was going with.
Old April 17th, 2012, 04:52 PM   #14 (permalink)
tonedreamer's Avatar
you could always try this approach...
"God is great, beer is good, and people are crazy!"
tonedreamer is offline   Reply With Quote
Old May 7th, 2012, 01:47 PM   #15 (permalink)
I know i haven't really updated this in a while... well its finished now! and it works a treat! Really pleased with it
It tunes up fine (theres a tuning screw that you cant see) and bends really smoothly
Only improvement would be more tension on the spring as i cant let the guitar go without it bending a tiny bit... so only a bit more tension really needed.
here are some pictures:
Just need a clean now.
Old May 7th, 2012, 01:59 PM   #16 (permalink)
HOBBSTER01's Avatar
well how does it work?
The Hobbster
Old May 7th, 2012, 02:40 PM   #17 (permalink)
This is a quick video i made playing the solo to Linda Ronstadt-Willin'
http://www.youtube.com/watch?v=yRmlQ...ature=youtu.be
Just needs a heavy spring or a couple of rungs cutting off.
Old May 7th, 2012, 05:24 PM   #18 (permalink)
HOBBSTER01's Avatar
what are you using for a stop/tuner?
The Hobbster
Old May 7th, 2012, 07:22 PM   #19 (permalink)
This is the stop... its a bit crude, but we might replace it using an allen key screw in the near future.
Old May 8th, 2012, 08:20 PM   #20 (permalink)
Silverface's Avatar
Instead of a heavier spring make yourself 2-3 more attachment points that will stretch the spring further. Then you can try different ones and see what feels best.
It would have been a good idea to look at some more designs first, but that's water under the bridge. Dave Evans installs an adjustable spring tension device on all Pull Strings - you might take a look at that to see what I mean about the attachment point, since with his you can move it a fairly long ways (which is great - loosen it to play sitting down, tighten it to play standing up.).
I've seen a lot of rough jobs that have worked well - for a while. But sooner or later you will likely run into friction issues (for now use dry teflon lube on every single moving part - it will make a huge difference), a bent arm and other problems. Think of this as a "prototype", look up a LOT of information and pics of other designs, and then figure out what you need to do to make a refined version of yours. One thing will be a MUCH heavier bellcrank/strap lever - that one will torque on you pretty soon.
Good effort though, and nice job figuring out how to play it!
“No Chops – Great Tone” ©
