| B-Bender Forum Bend your mind around the TDPRI's B-Bender Forum. |
Opinions on b-bender: Factory & after-market
Greetings All!
I've had several Telecasters over the past few years including an American Deluxe and a Classic Player Baja, but I've never been able to get that classic Nashville twang ala Marty Stuart or Kenny Vaughan. I've swapped-out guitars, I've tried changes in electronics (e.g., pickups, pots, etc.), I've tried everything! I just can't seem to get close to that textbook twang, and it doesn't seem to matter what amp is being used. Enter the Clarence White and other B-Bender Tele's. What can those of you who are experienced with these limited edition B-Bender guitars tell me about their overall tone? The Clarence White version (apparently equipped with Strat neck pickup) seems to sound truly awesome on YouTube videos, etc., but its my understanding that the Fender Custom Shop made only 200 of those guitars (making them virtually impossible to find or afford), and from what I can tell, the newer but lesser-valued Fender production-line B-Benders just don't compare. This leaves me with only one other option (the 'after-market' option) of having an entire B-bender mechanism retro-fitted into a suitable Telecaster by the original developer of the B-bender apparatus (Gene Parsons at www.StringBender.com), but here again, there's no guarantee of that 'twangy' tone, only the B-bending capability. Anybody have any meaningful views that they can share with me on this subject? I just can't seem to decide how best to move forward. |
I've owned several versions of teles, and nothing has gotten me closer to the sound you're talking about than low output bright pickups and steel saddles. As far as the bender, aftermarket is the way to go IMHO. Forrest lee jr. put one in my tele, and I love it. The amount of weight added was approximately 4 oz. after carving out the back. It works flawlessly, and the work is high quality.
Thanks Tele-Meister!
Regarding saddles and the reference to Forrest Lee, Jr., thank you for sharing those references with me. I'm grateful. I've already replaced the factory (Fender) brass saddles on my Baja Tele with a 'Bakersfield Twang' set from Glendale Guitars (i.e., 2x-steel + 1x-aluminum), and I'll definitely check into your friend Forrest Lee and his services re: a B-Bender mechanism. Sounds very cool! However, regarding pickups, could you give me an example of a specific make and model of pickup that you and others would consider to be "low output bright" for a Tele? I ask this because I swapped-out the relatively worthless Fender "Noiseless" pickups on my original American Deluxe some years ago for a set of Seymour Duncan's (Neck = Vintage Rhythm STL-1 @ 7.3k ohm/Bridge = STL-1B Vintage Broadcaster @ ~ 7.6k ohm), and it still wasn't anything near what I would call Nashville 'twangy'. I've looked at Wolfetone's and Lollar's and others, so any help at all on this would be greatly appreciated. |
I've used Don mare's in my last two teles, one had a Graf airship live (6.6k), and the other had a hayride (6.4k) in the bridge. Both give tons of cluck and twang. The rest is dependent upon your technique. My nocaster has twang, but I have to really dig in to get what I do without much effort from my other guitars...
Hwy145,
Thanks for the photos. Nice! Very nice indeed! I'll definitely have to look into Forrest Lee, Junior's work! One last thing . . . what are your views on the need for other changes in the electronic besides pickups? In other words, if a guy's already got a 3-saddle tailpiece with proper steel saddles and a decent set of "low output bright" pickups like the one's you've mentioned here from Don Mare, etc., does he still need to look at other potential changes to the electronics (i.e., pots, caps, etc.)? Or are those components less important? |
Probably not what you want to hear, but I've been doin this stuff for a very long time...If you can't get that Sound out of a Stock Baja Tele (Well Set-up)...it's either You or your Amp...A Bender will do nothing to capture the Sound you want...although they are Fun....
#8 (permalink) | |
#9 (permalink) | |
As for the B-bender mechanism itself leading to such tone, that was never my assertion. What I was alluding to was whether the limited edition Custom Shop Clarence White B-Bender's were equipped with bridge pickups that were inherently more conducive to that Nashville sound than my current Baja's. That was the intended question. I should also add that there are droves of people out there (here on TDPRI and elsewhere) who have referenced similar difficulties with this same tonal Tele quest. You'll see them talk (for example) about Brad Paisley and Marty Stuart and the critical need for compressors and this cap or that mod or whatevah! Thus, it isn't simply straight off-the-shelf stuff. |
To me and many others, the Fender Original Vintage Pickup that comes in the 52 RI is sorta the Benchmark for that Basic Tele Bridge sound, you might swap out that Broadcaster in the Baja for one of those ?
Thanks, that's good to know!
As I understand it, one or both of the two pickups in the Baja edition are somewhat prized, unlike other factory (OEM) offerings which are essentially fish-weights, so I'll assume from what you've said here that it must be the neck pickup which would then (presumably) would be worth keeping? Also, the fact that Don Mares and others offer bridge-only replacements for Tele's like his 6.4k ohm, staggered pole, A5 Hayride, would seem to support such a change. So the question becomes, are the Fender '52 RI bridge pickups even available on an after-market basis? |
#12 (permalink) | |
Sure are: Right here
http://www.darrenriley.com/shop/cart..._detail&p=1886 |
#14 (permalink) |
I have a set of OV's... I hated them... I love the Baja broadcaster pickup.. I'd swap you if'n yer interested.
"Everyone's got to be something... Me? I'm stupid... It's all I ever wanted to be... Shock me again!" |
Also, my P/W B-bender was installed by Brian Friend (BrianF). I am not sure if he's still doing bender installs. I tried contacting him in February by email with no response. At any rate, he does fantastic work. Many members here, including me, can vouch for his work and timeliness.
#16 (permalink) |
OV's??? Doh! OV = Original Vintage?!@#$%&*? (Got it!). And apparently OV means the same as '52RI?? Good Lord! Could this possibly GET any more confusing?
#17 (permalink) | |
I'm going to start by checking the resistance values for my two current Baja pickups, but meanwhile, does anyone know what the approximate resistance values for these Custom Shop '51 Nocasters are likely to be? Also, can anyone tell me how these '51 Nocaster's might compare (both in terms of resistance readings and tonal properties) with the '52 AVRI's? And lastly, I'll reiterate my earlier concern about other potential differences in the electronics besides pickups. A quick review of related threads here on TDPRI and elsewhere reveals a number of '52 AVRI owners who report a big difference in tone from a stock '51 Nocaster even after installing CS '51 Nocaster pickups in their '52 AVRI's. Needless to say, this strongly implies that pickups alone are not the entire story. Last edited by Dude; May 30th, 2011 at 04:12 PM. |
#18 (permalink) | ||
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right." Iris Dement Wag Often, Bark Little, Growl Seldom, Bite when Necessary..... |
#20 (permalink) | |
Nocasters are wound to nearly the same specs as OVs and they are the same magnets - 7.2Kish for the Bridge and 7Kish for the neck.. Nocasters are considered by some, to be darker than OVs. I do believe the have different wires though. As far as I am concerned, neither will get you that Bakersfield sound. IMO, that sound can be had by A5s wound to about 6 to 6.5K for the bridge. Owen Duffy makes a mean Bakersfield sounding set... The underwound nature of those pickups will give you the rich harmonics and uber-twang. The Baja set should be about 10K for the bridge which are A5s and about 5K for the neck which I believe are also A5s but they use the P bass magnets. There is a thread here where Alan Hamel, the orginator of the Twisted Tele neck, speaks of the construction. Your Broadcaster pickup should be very much like a Texas Special, only with flatpoles and plastic wires... Any rate, good luck with your tone quest...
