| B-Bender Forum Bend your mind around the TDPRI's B-Bender Forum. |
Hipshot on a Squier Standard
okay... my main gigging axe at the moment is a Squier standard. In fact, at the moment, all i have is my Squier tele and a Dano 12 string. Last year i got a hipshot and loved it. I had it on my MIA with the Callaham 3 saddle bridge. It was a super duper easy install. I drilled a hole for the B-string through the lip of the plate and slipped the teflon jibby in the hole, and then the string through the teflon and i was twanging. I didn't even bother with that insanely long 6 mile screw they give you to replace the stock strap screw. That sucka is way too long. I just used the regular strap screw. Later i added the 2 little extra screws.... I put a tennis ball on the end of that painful bar and I was b bending the night away. I love the hipshot.
So... now i see that most folks put the hipshot on the 3 saddle bridge or, if they have the 6 saddle, they use a 6 saddle bridge that has the offset saddle length adjust screw. Well, I don't have that. I have the one with the screw in the middle. (i dunno why, but i like those Al saddles the Squiers ship with, the only 6 saddle bridge i ever liked). How hard is it gonna be to get this sucka on a Squier Standard? Or are there alternate bridges that fit the Squier Standard that will allow me to easily and flawlessly use the hipshot? I don't much care about aesthetics so i am willing to drill in either the hardware or even the body, but my problem is that I don't have any tools and i don't know anyone in Seoul that works on guitars that is any good. hmm... I see hipshot has a replacement bridge, but that plate is $120 and i don't even know if it fits the Skwire. Anyone have any ideas? I really got used to the having the hipshot and really want to get it installed. I love gigging with the hipshot. I really miss having it. cheers, kp ps. Here is a picture of the Hipshot on the MIA "snot" caster (also a Timara String Drop (which i also miss having). You have no idea how hard it was to drill through that Callaham plate! That sucka is thick! |
for the curious
a close up of the Hipshot on the Callaham Bridge. This worked out great. I got the hole just right and the break angle of the string was perfect (which of course you can't really see on the picture).
Well, you might ask around and see if anyone has some of those offset saddles layin' around. If it's the right width, you could drill a hole for the adjust screw, and put the teflon tube into the old non-offset adjust screw hole, and run the string through there. Maybe?????
Unfortunately, no. If it was that easy we wouldn't be talking about drilling modifying plates with JD Weld and all that. Like the MIA the standard old skool tele bridgeplate is not a direct retrofit. Unlike the MIA no one appears to make a plate that you can swap. All the holes are in different places.
i think the easiest thing to do is move the screw from the center of the b-string saddle to the side of it. all you need is a drill and tab and die. or you could buy a single offset saddle of ebay.
#9 (permalink) | |
If not I think you can put a vintage type bridge in Squier too. Who cares about the new holes under the bridge anyway.
If you remove the noisy stuff inside the piano it makes a great house for a dog. |
#10 (permalink) | |
And... how can i just get one? wont that make 1/2 that saddle want to sit where the next saddle is? additionally, i now need three since this has G & B bending and a drop D. |
#11 (permalink) | ||
-k |
#12 (permalink) | ||
Trying to drill another hole to properly align an offset saddle is a non starter because of kp8's limited access to tools or someone who can do it for him. Besides, the old intonation screw holes are somewhat large and higher on the plate's lip than ideal for trying to have them coexist with an adjacent hole for an offset saddle. |
#13 (permalink) | |
I just installed a dual load three saddle vintage bridge plate on Squier. There's four holes to drill for the screws. I needed a hand drill, a screwdriver and 15 minutes. Ok, you're on the road and don't heve the tools with you, but you need to drill the holes and use the screwdriver to install the Hipshot anyway.
#14 (permalink) | |
It's not a lot of tools. It IS!!! a complicated job, b/c if the holes are not exactly in the right place the whole thing is ruined and the strings are running off one end of the board. NOT a job you want to screw up. I am glad you can do it. That's great, but there is no way i trust myself to do it, esp. without a shop and tools and experience. Too risky. |
#15 (permalink) | |
In this board there's plenty of nice tricks how to get the bridge installed straight and in the middle. I think the neatest one is to use two strings (not guitar strings, cotton for example) and make them go from both E string tuners into bridge to align the bridge. ![]() Then you can use a few pieces of masking tape to secure it into it's place, then drill. I don't think you can install a Hipshot more easily with the Squier modern bridge. I just don't see how to do that, looking the bridge closely.
#17 (permalink) |
Yes, that looks like a possibility... I think it depends on neck aligment, maybe it would need a shim too. I think the strigs might go even above the bridge plate edge, like this:
![]() This picture is before shimming so I wasn't able to use the string retainers on Hipshot. On your mod the three saddles are the key to success, but there's drilling holes thru the bridge for the three saddles involved. Or for one if just remove the saddles for B and E strings.
#18 (permalink) | |
That bridge was from a current production Squier Standard, so it will be a direct fit for his Tele. |
| hipshot b on MIM standard? questions... | Gene Machine | B-Bender Forum | 17 | January 6th, 2009 11:46 PM |
| Hipshot on American Standard | jodie | B-Bender Forum | 2 | November 26th, 2007 10:01 PM |
| Hipshot on a Squier 51? | Ignatius | B-Bender Forum | 1 | July 24th, 2007 06:07 PM |
| Need help with Hipshot Standard B bender install | TeleDon | B-Bender Forum | 2 | September 25th, 2006 10:34 PM |
| Will Ray or standard hipshot? | RonWhitney | B-Bender Forum | 14 | November 20th, 2004 01:50 PM |
