Old September 3rd, 2009, 10:46 AM   #1 (permalink)
old_picker's Avatar
sho-bud info
sorry to post off topic but this forum is about as close as i can find
i am looking at buying a sho-bud 10 string single neck off a mate of mine and am looking for some background info
seems to be very little on these around the net
appreciate any links that might help out
ray
old_picker is offline   Reply With Quote
Old September 3rd, 2009, 10:55 AM   #2 (permalink)
Sho-Bud made nice steels, some are real classics. Single decks start out with the Maverick, a student level 3 pedals and 1 knee lever. I am not sure if the one you are looking at is a Maverick but I just thought I would mention that they made a student model.
Personally I would try to find more than just a student model as you will quickly want more than 1 knee lever.
Try the "Steel Guitar Forum" or it might be called the "Steel Guitar Pages" website. Like this place it is full of alot of nice folks with a ton on knowledge.
Good luck. I kind of want to get another steel myself, I was stupid and sold mine a few years ago.
3 Chord is offline   Reply With Quote
Old September 3rd, 2009, 07:28 PM   #3 (permalink)
old_picker's Avatar
thanks for that - i guess i am a student
i played a little lap steel and it worked pretty good
i got the chance to buy this steel on a good price
its got an all maple body Aussie$1,000
ray
Old September 4th, 2009, 02:45 AM   #4 (permalink)
I owned a Sho-Bud Maverick with two knee levers. It was enough for me to learn on, then sit in with, then get gigs with. Then I sold it and got a Sho-Bud Pro I 12 string. Many years later, it was stolen and I ended up getting a 12 string Sierra. Go to Steel Guitar Forum.
Raybob is offline   Reply With Quote
Old September 4th, 2009, 04:00 AM   #5 (permalink)
Ormond's Avatar
Yea, the Forum : for the "For Sale" page
http://bb.steelguitarforum.com/viewf...0785748106b2e2
Ormond is offline   Reply With Quote
Old September 6th, 2009, 02:41 PM   #6 (permalink)
Post a pic, and I probably can tell ya what you want to know. I have 4 Shobuds. '59 Perm, '63 Fingertip, '67 S-10 rack and barrels, ''74 S-10 3 &6. I'm sick! Plus, I'm in contact with many others with my disease.
jmiles is offline   Reply With Quote
Old September 7th, 2009, 09:19 AM   #7 (permalink)
..and they reckon swine flu is contageous!...
Heaven: A Bassman 410, a good pizza, and a nice lie down
gumbo is offline   Reply With Quote
Old September 13th, 2009, 11:02 AM   #8 (permalink)
old_picker's Avatar
went out and bought it friday nite - and just read a whole bunch of stuff bagging out mavericks
seems pretty solid and everything works fine - it also stays in tune
very noisy though - pickup is not earthed
here tis
ray
Old September 13th, 2009, 08:35 PM   #9 (permalink)
OP, post a pick of the underside mechanicals please. Although a student guitar, you can certainly make some beautiful music on this guitar. But, sooner or later, you're gonna wanna step up. Most Mavs are pretty much a fixed copedant, and knee levers can't be added. But, it's a ShoBud, and things changed constantly there. Your guitar has a wood wrap-around changer. Some of the best sounding Buds have that changer, even though it's pretty primitive. I would say that your guitar, due to the middle position of the pedals, was made between late '67 and '70. It's nice that you got one from before they went to the bodies covered with contact paper.
Flip that sucker over, and post a pic. Then I might be able to tell you more. Another thing to look for when it's upside down, is, how many wires are coming from the pickup? I bought a '74 guitar that didn't have the coil-tapped pickup. Or so I thought. When I flipped her, I found one of the pup wires was just taped up! You might be able to add a coil tap. I did.
Old September 13th, 2009, 08:56 PM   #10 (permalink)
old_picker's Avatar
here she is under the skirt
btw there is definitely only two wires off the pup so i am gonna have to work out some way of grounding it...
i thought of just shorting the return back to a copper strap screwed to the cabinet and wired to one of the string pull mounts. trouble is which is the hot red or black. i would guess red is hot
ray
Old September 14th, 2009, 04:28 AM   #11 (permalink)
That looks identical to one I had in '77 and sold later in '78 in SF bay area except mine had two knee levers. One of the levers lowered the lower E string, the other lever raised the G# strings. I recall it had excellent tone. You can add one more lever if you want to but it's enough with one lever to get to know if you're going to like pedal steel or not. I got to where I was gigging with mine, then bought a single 12.
If you decide to stay with steel, you WILL want to get a different one. The Maverick will only have one tunable change on each string. Most pro models will have three tunable raises and at least two tunable lowers if not three.
I assume you know that it's supposed to be tuned E9th as in Buddy Emmons setup except for the knee levers.
Black should be ground but check to be sure the wire goes to the ground lug of the jack.
Old September 14th, 2009, 12:54 PM   #12 (permalink)
"be sure the wire goes to the ground lug of the jack."
AND,,, run a wire from that ground lug to one of the changer mounting screws. String ground.
New here and looking for info bigjoe1128 Welcome Wagon 4 May 8th, 2009 04:28 PM
Would like some Info 250Keith Amp Central Station 0 June 17th, 2007 03:41 PM
Info on amp sandman72202 Amp Central Station 2 February 6th, 2006 02:03 AM
need info on old amp wakiyan_luta Amp Central Station 8 January 26th, 2005 02:59 PM
Sum old fun and info----- 0le FUZZY Telecaster Discussion Forum 41 February 13th, 2004 02:11 PM
