Old September 1st, 2009, 11:36 PM   #1 (permalink)
b bender repair
I would like some info on how to fix my Parsons/Green b bender. When I release my bend, there's a metallic click where the strap button mechanism hits the metal plate on the back of the guitar. I'm thinking there's an adjustment that could be made in the gaggle of nuts and bolts under the plate. Any suggestions?
uncawooz is offline   Reply With Quote
Old September 1st, 2009, 11:48 PM   #2 (permalink)
Ormond's Avatar
It is not that bad a gaggle, have a look. BUT DO NOT TAKE OUT ALL THE SCREWS!!!!!!
Just take out the small ones around the edges. I made the mistake of unscrewing the big ones and the thing exploded all over the place. And it is a ***** trying to get the spring re-streched and attached.
If you remove the bender it be become instantly clear where the click is coming from...you can pad it if need be.
Ormond is offline   Reply With Quote
Old September 2nd, 2009, 08:01 AM   #3 (permalink)
I've had the back plate off and that's kind of how I got into trouble. I adjusted the length of the spring and put it back and everything is fine except for the click. I know where it's coming from (I can see it) and I could pad it but I'm wodering if there's an adjustment that will keep the metal strap holder from clicking into the back plate. The gaggle of nuts where I'm thinking the adjustment could be made is right under the biggest screw on the back plate-the one you for sure don't want to take out! But that biggest screw is an adjustment for something. Any idea what?
Old September 2nd, 2009, 07:33 PM   #4 (permalink)
13ontheB's Avatar
Did you check to see if the cork pad where the adjustment mechanism comes rest is still in place? I had the same problem with the click,it was caused by the lever hitting the bottom of the slot when it returned after a bend,the pad on my mechanism had completely disapeared.You should have a slight gap between the lever and the bottom of the slot when the lever is at rest,if you do not have a gap then the pad is missing inside the bender.
BB
13ontheB is offline   Reply With Quote
Old September 2nd, 2009, 07:51 PM   #5 (permalink)
13ontheB's Avatar
Go to my profile,click on all threads started by me and scroll down to" P/G Tele setup" thread.. All will be revealed.
Good Luck
BB
Old September 2nd, 2009, 08:09 PM   #6 (permalink)
Absolutely right! The cork pad had disintegrated. Put a new one in place and it works like a charm! Thanks a million!
Old September 2nd, 2009, 08:30 PM   #7 (permalink)
The Stringbender.com site is excellent! Thanks to all of you for your timely help. I'm now happily (and quietly) bending!
Old September 3rd, 2009, 03:17 PM   #8 (permalink)
Dogbear's Avatar
The pads on my Hipshot P/G were plastic buttons. It didn't take long for that top pad to side sideways and fall off. I replaced both of mine with glued thick leather pads and haven't had a problem since. I've never had a problem with my Fender unit and the pads there also appear to leather.
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right."
Iris Dement
Dogbear is offline   Reply With Quote
B-bender Repair near Wash DC t-loader B-Bender Forum 9 October 5th, 2008 04:40 PM
B-Bender Repair Question bstolte B-Bender Forum 2 June 15th, 2008 10:02 PM
Quadruple Bender/Bending setup??? B-Bender, G-Bender, E-bender/lever, etc. Screenery B-Bender Forum 9 May 24th, 2008 06:28 AM
adding a G bender to tele with B bender already there ? cbnutt B-Bender Forum 14 May 20th, 2007 03:08 AM
new b-bender project diary. rare shelton b-bender content, self installation :-) soltwanger Telecaster Discussion Forum 51 March 21st, 2007 01:58 PM
