Old August 29th, 2009, 04:05 PM   #1 (permalink)
b-bender in a Jack Pine Body?
is pine to soft for a b-bender to be installed and be stable? i am thinking of getting BnW B and G benders installed in a pine body.
Thanks
Guitartom_ca is offline   Reply With Quote
Old August 29th, 2009, 05:34 PM   #2 (permalink)
Dogbear's Avatar
This link gives relative hardness for most woods. Surface hardness in the wood industry is measured by the load or force required to embed a steel ball, 0.444 inch in diameter, to a depth of one-half its diameter. IMHO, I don't think using Jack Pine would be a problem, however considering the cost of the bender, a better grade of wood body might be a better idea.
http://www.cabinetmakeronline.com/Vi....aspx?id=33094
Hardwoods
Very soft (under 450 pounds)
•Aspen
•Basswood
•Eastern cottonwood
Quite soft (450-600)
•Butternut
•Yellow-poplar (tulip poplar)
•Red alder
•Spanish cedar
Softwoods
•Ponderosa pine
•Red pine
•Jack pine
•Alaska yellow cedar
•Tamarack
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right."
Iris Dement
Dogbear is offline   Reply With Quote
Old August 29th, 2009, 07:09 PM   #3 (permalink)
BrianF's Avatar
I installed a PW in Get Bent's Pinecaster that he named "The Ranch Hand"
http://www.tdpri.com/forum/b-bender-...ou-brianf.html
Old September 26th, 2009, 02:25 AM   #4 (permalink)
Greg Seaman's Avatar
Excellent Job on the PW Bender install, Brian. The black paint is a nice touch. Looks great! I bet it works perfectly too.
Guitar Tom: I see no reason why you could not install a PW type bender in a pine body as long as it's a decent grade of pine. Obviously, it's been done (as we can see). Have you tried a Hipshot B-Bender? I like it better than a strap activated rig like Uncle Geno's (Gene White).
I own a '97 Fender Tele with a factory installed Parson's Green and a G&L Will Ray with a Hipshot. I like the Hipshot better both in sound and action. When Hipshot Benders first came out (way back in the Bronze Age), I didn't like the concept or the look. I felt that way for years until I tried one. Listening to Will Ray years ago prompted me to try one. As soon as I did, I was hooked -for life!
The Hipshot has a longer throw than the Parsons/Green resulting in a more dramatic and easier to control action. I believe the resulting effect is more pedal steel-like.
I realize that there are long throw Parsons type benders available -but the price. YIKES!! Hipshot works great for me. It's also east to install, less expensive and less invasive.
Try one on your Pine-O-Caster. Don't hack it up if you don't have to! Just my humble advice -but I'm just an early primate with an I.Q. to match. Good luck and happy bending!
Greg Seaman is offline   Reply With Quote
Pine body? hardie775 Tele Home Depot 52 July 24th, 2009 06:46 PM
Pine body? Musicman1 Telecaster Discussion Forum 4 July 12th, 2008 10:56 PM
Lumber Jack Advice Needed For Mutant Adirondack Pine Teles Groovey Records Tele-Tech 15 April 23rd, 2008 04:49 PM
where can i get a pine body? SpaceyBen Telecaster Discussion Forum 37 October 3rd, 2006 03:35 PM
Pine Body sonche99 Telecaster Discussion Forum 40 October 8th, 2005 02:50 PM
