Old August 21st, 2009, 11:43 AM   #1 (permalink)
piaggio's Avatar
string tree blues
hi everybody.
in my new b-bender hipshot tele, I took off the string tree, in order to reduce the friction points, and mounted a set of spretzel locking tuners that-being made with different heights-allowed me to go without the tree.
the guitar and the b-bender works a charm, BUT : if I play with a little more strenght on my high E, it often "escapes" the from the nut.
the simple way seems to be to put back in place the string tree, but if I could keep the B-string free from it, I would be happy.
I was wondering if a single string -with an asymmetrical tension-could cause trouble to the string tree's stability.
is a little doubt, I know...
"A lot of things can wait, but the search of god cannot wait" - George Harrison
piaggio is offline   Reply With Quote
Old August 22nd, 2009, 04:55 PM   #2 (permalink)
Originally Posted by piaggio View Post
hi everybody.
I use roller string trees with my b-bender. Got them from Stew-Mac. Cheap and work fine.
Raybob is offline   Reply With Quote
Old August 22nd, 2009, 08:08 PM   #3 (permalink)
helle_man's Avatar
I always have to use string trees or I pop my E and B out of the nut. Just use a Teflon gel on the tree. I use Big Bends Nut Sauce.
Will Ray says - "More Guitars, Less War".
helle_man is offline   Reply With Quote
Old August 22nd, 2009, 08:35 PM   #4 (permalink)
bargoedboy's Avatar
i use standard tree`s and fill up underside with graphite dust and glue till its hard then cut a slot for string to sit in and replace. from head on looks standard but underneath works just like a graphite string tree. first did it for a mate who plays for shadows and those fans want a strat to look like a strat!
bargoedboy is offline   Reply With Quote
Old August 24th, 2009, 04:27 PM   #5 (permalink)
piaggio's Avatar
wow ! think I'll do as THE HELLE-MAN says !
it's like have a problem on your PC and bill gates comes and give you some advice
thank you everybody !
Old August 25th, 2009, 04:26 PM   #6 (permalink)
I replaced both string trees...........
on my main tele with a couple I got from Stewart/MacDonald which were made entirely of graphite. They work like a charm with no de-tuning problems and never have to be lubricated with anything......JH in Va.
Ralph Mooney rules!!
J. Hayes is offline   Reply With Quote
Old August 26th, 2009, 11:40 PM   #7 (permalink)
You should be able to grind or cut off the B side of a sting tree. It mounts solidly to the headstock, I don't think it would be a problem. There's not a whole lot of tension under a string tree.
Staggered Mag is offline   Reply With Quote
Old September 13th, 2009, 03:57 AM   #8 (permalink)
VENDOR
ForrestLeeJr's Avatar
put the tree back on, get a #2 pencil (or as Will uses... Big Bends Nut Sauce) and apply it on the string under the tree.
I keep a pencil in my case. It's graphite at it's cheapest... and I rub the pencil on the string at the tree, and on the nut (ALL STRINGS) and on the bridge peices.
If you do a lot of below the nut bends as well, the pencil trick will take care of any string sticking on the low end as well. And everybody has a pencil layin around right?
I should market that! B bender pencils...lol
I would like to add, stainless steel strings last a hell of a lot longer when you use a bender... nuff said.
BTW Will, you and Tim Wallis are my heroes!
ForrestLeeJr is offline   Reply With Quote
D/G string tree. Yes or no? backporchmusic Telecaster Discussion Forum 4 July 24th, 2009 04:20 AM
What is a string tree fonmunky Telecaster Discussion Forum 8 February 21st, 2009 11:36 PM
String tree or no string tree? SpinWheelz Telecaster Discussion Forum 11 January 7th, 2009 09:59 AM
String tree ? ASC67 Stratocaster Discussion Forum 2 November 14th, 2008 06:47 PM
String Tree Breaks String Twangster Telecaster Discussion Forum 2 September 10th, 2004 03:43 PM
